Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer Neptune, Model MDE5500AYN
My Maytag dryer has begun to make a sound that is not right...It has worked fine until now.....I put a load of laundry in last evening and went back upstairs to check it later, and it was making a sound that sounds like when you have a zippered jacket or something just a little different in your dryer that's hitting against the sides of the drum. It is still heating, but I don't want to run it in case I may do more damage. I opened the door and held the switch with my finger and turned the dryer on (I know that I'm not suppose to do that, but I wanted to try to find out where the sound was coming from), and it sounds like the noise is coming from the back of the dryer. It's a continuous sound.
  • 639 Answers
Peace
ngfam1 at your service,
This may be a couple of things.
1- The belt may be bad or twisted or frayed and ready to break!
Or,
2-The drum may be out of alignment and not be roling smothly over the roller glides that it should be spinning on!
I am not there to give hands on diagnoses.
But I can give you a good service that is nation wide!
A&E Factory service .
They answer 24/7 to make appointments!
And have a reasonable service charge of $75 around our area
Remember though, if the unit is 10 years old or more it may not be advisable to put good money into bad!
New appliances are much more efficient and pay for them selves in only a few years!
Bless You,ngfam1
Please give me a good rating in our fiya.com sight before you sign off!
ngafm1
Posted on Sep 03, 2008
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
Model mde5500ayn
Try unplugging it .Sounds like it could be in your board? leave it unplugged for about 3 hours I know it sounds silly it should come up blank sometimes it comes on and works if it keeps doing it replace your board
Nov 12, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune dryer, works fine until the last 5 to 10 minutes and then starts to make a loud skreeching noise. Suggestions??
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 18, 2011 | Maytag Neptune MDG9700A Gas Dryer
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Can i change which side the driver vent is located?
Hello Laurie. Your dryer allows rear vent, left or right vent. Here is a diagram which shows you all three http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYW/3048/0151200/M0606011/00002?blt=06&prst=&shdMod=
Just pull the dryer out from the wall to access the rear and sides. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune gas dryer front loader 9 years old has begun to squeak what is the most likely cause?
Either one of the rollers or the idler pulley is causing the squeak. Most common to go bad in a maytag dryer is the roller on the right, it sits just above the heating element. You need to take the drum out and spin each of the rollers and the idler pulley to determine which one is the problem, and replace it. good luck. Shane
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motor kicks out
sounds like you have a bad motor
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Apr 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
151 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
