Question about Xerox Phaser 8400 Laser Printer
8400 fault code
Getting fault code 37,016 43:28128 Anyone ever seen this code before?
  • 300 Answers
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
Posted on Sep 03, 2008
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
Xerox on a 8400 faults code 37004 403B25998 what does it mean
37,004 is a printhead error, specifically that a Reservoir heater isn't drawing power from the power supply.
The printhead 650-4303-00 is expensive, unfortunately.
Whit
Item, Inc.
May 06, 2010 | Xerox Phaser 8400 Laser Printer
Iam getting an error code on my xerox phaser 8400 ... code # 08,055.44:92360
. Check for spilled ink and ink overflow from printhead reservoirs. If reservoirs have overflowed or a large amount of ink is present in bottom of machine, the printer has most likely been tilted, tipped or moved while hot and this may not be covered under normal warranty or service agreement. Contact Customer and Technical Support for additional troubleshooting assistance. 3. Check printhead wiper, wiper belts and drive gears for damage. 4. Check the wiper alignment and physically align wiper as outlined in Section 6 of Service Manual, Wiper Alignment Procedure. Run the Wiper Alignment test. Reference Section 3 of Service Manual 8,0XX.xx Errors - Wiper/Media Drive Faults. 5. Run the Head Maintenance Clutch test.
Mar 02, 2010 | Xerox Phaser 8400 Laser Printer
I am looking to unlock region code for my DV 8400
Don't think there is just a code. We used to do the Dv4400 with a firmware update to MR them. you would need the 8400 firmware...I've never seen it thoughh
Nov 02, 2009 | Marantz DV-8400 DVD Player
Anyone help with fault code 08.007.41.122.171 xerox phazer 8400 pleas
That is normally a RAM failure. You can try going to the back of the machine and opening the plate which covers the memory stick or sticks, depending on how much memory you have. Remove and reseat the memory. You may have had a memory failure, memory dump or electronics module failure. Kind of a difficult one to trouble shoot.
May 06, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400 error code
That is related to the print head heating. Normally one of the print head heaters fails which requires replacement of the print head. The other item I have seen fail and cause that code is the electronics module. Both are very expensive.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Fault code
well..it's a system error code..is this an older machine, by chance?
Aug 20, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault
I have the same problem. Xerox says they need to send someone out and can not tell me what this code means.
Prior to the error I have having light streaking on the page. Took everything apart and cleaned and it worked OK for 2 days then returned to streaks.
If anyone knows what to look for please offer assistance.
Jul 24, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400
That is related to the memory or the entire electronics module.
There is no specific 11,009 codes that I can find.
I am basing this on the fact that the 11 codes are all based on the memories and ECT Module.
Nov 19, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
208 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
