Question about Maytag Neptune MDE4000 Electric Dryer
Top Panel I need to repair a drum baffle. How do you lift the top panel of the dryer?
  • 71 Answers
There are 2 philips screws on the front panel 3" up from the bottomm remove screws and pull front panel from bottom then replace baffle scewes from the bottom
Posted on Dec 24, 2008
Replacement of a drum baffle, how to?
inside the door thier is 2 screws that hold the hinge to the front panel remove those and the 2 on the other side gently lift and pull the door off. pull the front panel off and look and find directly below the top a clip that holds down the top to the front panel remove those clips (one on each side) pivot up the top and rotate the drum by hand so that the baffle that needs to be replaced is on the top. replace baffle and reassamble in reverse order
Jul 19, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
One of the plastic pieces inside the dryer drum is loose. How do I remove the dryer top so I can tighten the screws>
OPEN THE DOOR. INSIDE THE OPENING ARE FOUR SCREWS 2 ON EACH SIDE. REMOVE THESE. EACH SIDE OF THE FRONT PANEL KIND ROLL OF FROM INSIDE TO OUT AT THE TOP. OR JUST PULL. BRING THE FRONT PANEL OUT TO A 45 DEGREE ANGLE. CLOSE THE DOOR AND LIFT UP ON THE FRONT PANEL. AT THE FRONT OF EACH TOP CORNER THERE ARE HOOKS HOLDING DOWN THE TOP. THEY ARE SCREWED IN PLCE WITH A 5/16 TH HEX HEAD SCREW. REMOVE THOSE AND THE TOP CAN LIFT UP.
Apr 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer has a loose dryer drum baffle. How to i get to it inorder to tighten the screws? Do I remove the top
unplug Dryer, open door, Remove two door hinge screws going into front panel, remove two screws on opposite side. Grab front panel on upper sides and twist and pull front panel out. Panel sits on two clips at bottom so you have to tip panel out to unhook from the bottom. You will see a metal hook with two screws in it that holds down the top of the dryer on each side. Remove the screws and hook bracket. Make sure you note how it reinstalls. Top will now lift up and lean back against a wall. It is hinged in back. You can now easily get to the drum baffle screws. Good Luck, Appliance Specialists
Dec 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the finns inside the dryer is loose, how do I tighten it?
To tighten the drum baffles, all you have to do is UNPLUG the dryer and lift the top panel. The bolts that hold the baffles in place are located on the outside perimeter of the drum. There's usually a minimum of two per baffle. If you cannot figure out how to lift the top panel, post back with your complete model number (located on a nameplate around the door opening or back of the operator console) so that I may be able to assist you further. I hope this helps you.
Oct 28, 2009 | Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
Nov 21, 2008 | Maytag Dryers
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
Fix Loose Baffles
The two screws that hold the door door hinges and the two on the opposite side of the door opening hold the front panel in place. Once you remove the door and the other two screws the front panel should swing down to access the screws that hold down the top. But you may be able to reach the baffle screws once the front cover is removed.
Oct 30, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
