Question about Oregon Scientific Computers & Internet
I have a pair Transcievers TP-326 PMR, which on one of them it has become locked, with a key icon just to the right of the batt state icon. I cannot find a way of unlocking it, and there is no reference to how to lock/unlock the unit in the owners manual supplied with the units, and there is no button marked "Lock". The other unit is unlocked and works OK. I would appreciate your comments. Thankyou.
Take the battery cover off and at the bottom there's a padlock icon - push a small pin in and press the 'reset' (or unlock) switch - job done.
Posted on Jun 01, 2009
I have a 1994uick lasabra lost my keyhole do I get a key for stating it
Apart from my other suggestion, you can get a new lock and key from a scrap yard. Get someone to fit the new ignition lock. To pair the antitheft system, you have to disconnect the battery for 2 hours and then reconnect with the key in the lock.
Dec 30, 2016 | 1994 Buick LeSabre
I am looking for a shibaura gt 14 work shop manual please state price.Brendan
Only this available online for $14.99 but wrong model.
http://www.manuals.club/document.php?iddocument=Dbp4y9cx9e
This is the right model, but no price. Copy and paste with the spaces,
http://www.manuals.club/document_order_init.php?search=shibaura gt 14 &doctype=4
or click here and use the search feature.
http://www.manuals.club/results.php
Or you could contact them direct.
SHIBAURA EUROPE BV
Begonialaan 7
6851 TE Huissen
the Netherlands
T. 0031 (0)26 326 9999
F. 0031 (0)26 326 9990
E. info@shibaura.com
SHIBAURA ST445 Tractor
May 23, 2016 | Cars & Trucks
How do i stop key pad going to tp of page on ipad 2
You can hold down the kb icon at the bottom right corner. That will give you 2 choices, slide your hand to the selection you wont.
Hope this helps.
Feb 01, 2015 | Cell Phones
My key will not lock my doors, trunk nor will it start the car... I change the batt. it use 2025 litum batt. My email:tgbinyard@yahoo.com my name is Tolonda
is the your car closing aid working fine? if not possibly blown fuse for center locking pump or faulty center locking pump some time can be faulty key if you have the other keys? is the problem same for them faulty fuse or center-locking pump, if you have only one key some time can be faulty key also, if your closing aid also not working check fuse first fuse is located below fuse box at right rear seat fuse is 15 amp yellow, is the fuse OK disconnect battery ground cable for a few minute and fix it back and check, if start to work possibly vacuum leaking from some where, like door locks or boot lid lock need to be diagnose, after disconnect battery you have to be normalize steering by turning two times from left end to right and otherwise abs message will appear on the cluster, also sunroof + windows need to be normalize is this information helped you? if yes please vote me and leave a comment,
Oct 15, 2010 | 1999 Mercedes-Benz S-Class
How do you get the ps3 to pick up the blue tooth head set
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Won't produce sound batts charged says it is paired says it is connected
It will produce sound when you click open the Volume icon in the system tray in the right bottom corner of the screen. Here you will find that the MIC has been muted (Old habit of Windows). Remove the tick from the box of mic and save. Now you and others will hear you talk. And remember to unmute it whenever you want to talk to anyone.
Dec 13, 2009 | Computers & Internet
Hp 4108 vs 2524
It has to be either the cable or the transcievers. Do you have a spare pair you can try instead?
Don't forget that HP has free tech support at 866-myprocurve also. They are excellent.
Jun 19, 2009 | HP ProCurve 2524 24x10/100 Mbps Networking...
Golf indicator lights flashing when locking with beeper
possible ecm reset needed (electronic control module) This is easy to do at home with a pair of visegrips or a wrench set. anyway the idea is to disconnect the car batt for atleast 2-3 minutes and with the key out of the ignition replace the batt terminals and tighten them wait 2-3 minutes and then get in car turn key only to light the dash this is called the post, once the dash has sat in the active position for the time said 2-3 minutes, turn car off remove key replace key and start the car let it run for a min or so and then turn off and exit the car and proceed to activate the alarm if the prob still is there i then suggest an ecm test any mechanic or dealer will test it for a nominal fee, if there is any thing at all not right with the car this test will get to the root. and if the test is showing no problems with the car the issue is most likely in the electronic keychain alarm keylock box
Jun 01, 2009 | 1996 Volkswagen Golf
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Computers & Internet Logo
173 people viewed this question
Top Oregon Scientific Computers & Internet Experts
David Payne
David Payne
Are you an Oregon Scientific Computer and Internet Expert? Answer questions, earn points and help others
