Goodmans MICRO1104DAB. DAB section has failed. CD/ amplifier section OK. Error message reads D1 Test A Digitall Network. The DAB reception is normally OK at this location. Scroll up/ down shows the usual stations have been scanned and found, but each station is preceeded by 'D1 Test A' Any ideas?
5 Suggested Answers
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
SOURCE: DAB RADIO MATSUI MATCR 515D-
It is possible for the display to be set so low that it is not illuminated at all. With the radio off (i.e. the set must be in standby), press and hold TUNE+ to raise the brightness level.
If this gets the display back, you may be able to see what has happened to the tuning. e.g. check whether the tuner is set to FM or DAB etc.
Posted on Sep 02, 2008
SOURCE: Have lost four preset
Finally sussed out how to (re)set presets, overall you need a little patience:
Probably best to press Autotune before we set off and let it do its thing.
Press 'presets' and find a free channel or the one you want to change, leave it until you can hear the station its on play.
Now, press 'jog/select' and WAIT until it says <SELECT> (but don't wait too long when it says this or you'll have to start again)
Use dial to find station you want AND LEAVE to tune in.
Press AND hold presets down until number flashes.
Press jog/select once briefly (normally).
Press presets once briefly...it should now say "Saved"
Leave to save for a few seconds.
Voila!
You can now change station either by pressing Presets and moving dial...waiting for the station to load OR press jog/select to manually tune to the station of your choice using the dial.
Posted on Mar 01, 2011
  • 1116 Answers
SOURCE: I have 6 preset DAB
You can download your manual for the radio at this link:
http://lowryelectronics.webeden.co.uk/#/gsdab0904/4536733630
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 01, 2011
Connection failed
This is a message from the AVR2312CI attempting to connect to the Internet through it's local area network Ethernet socket. Turn this feature off in the setup section if you do not need to connect. If you do want to connect, make sure you have a good connection to your router and, if necessary, make sure your security software is not blocking the connection. If that fails, turn off modem, router(s) and amplifier then switch on in the order:
modem,router(s) and finally your AVR2312CI.
That should solve your error message.
Regards, Don.
May 31, 2014 | Denon AVR-2312CI
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
Teac CR H250 plug into arial
The only thing that would damage DAB reciever is lightning hitting the arial. But all you have to do is unplug during a storm. You might get a better reception with the £100 job, but I think he was a conman!
If in doubt read the instructions!
Jan 29, 2010 | Audio Players & Recorders
Lost all DAB stations recently and purchased an
GOT NEW DAB MICRO IT KEEPS MAKING A RACKET BUT WHEN I TOUCH AREIAL WIRE I CAN GET STATION BACK WHAT IS THE PROB PLEASE HELP
Dec 18, 2009 | Audio Players & Recorders
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
May 20, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
COMPATABILITY
MY GOODMANS CAR CD PLAYER AS BROKE , THINKING OF BUYING ANOTHER WILL IT JUST SLOT IN TO THE EXSISTING FASIA. OR WILL I HAVE TO REWIRE AGAIN.
Jan 09, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
Faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Mar 06, 2008 | Televison & Video
Need CD Laser replacement for AVIC-D1
hi nwww.carradiospares.co.uk shpould be able to help if you email them
Regards
Mark
www.blueice-electronics.co.uk
Nov 21, 2007 | Pioneer AVIC-D1 Car Video Player
52 people viewed this question
 Grubhead
Grubhead
