Question about Samsung RS2630SH Side by Side Refrigerator
Water dipenser i have a samsung model RS21DCSV fridge freezer and have ice still being made but the cold water is not working, i have changed the in line water filter but the filter light is still on and no water
  • Anonymous Sep 04, 2008
    I came home from work last night and there was vibrating noise coming from the fridge removed the 2 small deodorizer covers( midway down the fridge twin cooling area) and found the one on the left was frozen.the vibration comes and goes as the temp changes.came in from work today to find the ice is still working but my water dispenser is not working.not sure if both are linked !!!!!
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Posted on Sep 27, 2008
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Icemaker tuns but ice does not drop out
OK the reason the Ice isn't dropping is that the element under the icecube tray isn't working. You'll need a new Ice tray with element I'd be guessing, but see how you can buy it. Some models you need a whole new ice maker. Cheers
May 21, 2009 | Samsung RM255LASH Side by Side...
Model rs21dcsv freeze is working but fridge is not working
CHeck to see if there is ice built up on the back wall of the freezer. If so you have a defrost problem. Manually defrost it then take the back wall out of the frezer and check ohms on the heater if heater is ok then replace just the defrost timer and thermostat. If heater is bad replace all three.
Nov 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Samsung rs21dcsv refridgerator
THE PROBLEM CANT BE ON THE FRIDGES PIPES.THE PROBLEM MUST BE AT THE FILTER OR ON THE WATERSUPPLY.
Feb 13, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
383 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
