Question about ASUS Eee 4G Notebook
Notebook my asus notebook switches on bur does not go to my main menu. it just shows me a blank screen. it shows that there is a problem but i cannot see what the problem is as it flickers to fast for me to see.
    Guru:
  • 257 Answers
Then try this test youself once you switch on your system then press your caplock key on your keyboard and if it brings light that means the motherboard is good and if the light comes on and immediately off then the motherboard is ok but the processor is bad then you disassemble your sytem then change the processor or check if the processor fan is blowing well then make sure the fan is working then change them and hope all is ok.
Any question
Posted on Sep 03, 2008
Why does my asus notbook not turn on and is blank?
Sounds like the battery is completely flat.
Ensure your charger is plugged into the mains socket and plug into your notebook. Leave to charge for about an hour, then it should switch on.
When you have finished using it, make sure it is shut down correctly and leave it charging over night for a full charge. (When it is switched on whilst charging, it takes much longer to charge.)
Jun 24, 2014 | ASUS B50A-B1 (90NQ9A1232244EQL150YB50AB1)...
My asus inbuilt laptop screen goes blank. what is the solution ?
For a start try to remove the battery, wait for some time, then insert the battery. Turn on the notebook. Maybe, it will be useful for you. Meanwhile, maybe you need to reinstall drivers for your notebook which you can try to find here ASUS Notebook Laptop driver download
Mar 26, 2014 | ASUS A8Jm Notebook
Laptop powers up but a blank screen shows with two green lights showing up top whats the problem
PLug the laptop into an external monitor to see if you get video to the external screen.  You should have a vga port on your laptop, connect it to the laptop and then turn it on.  If you see video the onboard video card on the laptop is fine and most likely you have a bad lcd.  On the other hand if by "powers up and then goes to a blank screen" you mean its posting you see the asus splash screen and instaed of going into windows you see a blank screen.  in that case you mos likely have a bad hard drive or corrupt operating system.  You can test the hard drive by downloading dft and booting from that cd.  here is a link to dft http://www.hitachigst.com/support/downloads/#DFT
May 15, 2011 | ASUS X83VB-X2 Notebook
AMD Puma-based Asus M51Ta stalls at power up, screen is blank.
Have you tried booting and pressing F2 to get in the bios?
If that works you can check the boot devices and order of usage. Make sure the HDD is first.
Apart from that you can reboot and press F8 to get in the Windows boot menu, where you can try the Safe Mode.
If all this fails, the Windows configuration is somehow corrupt. You can try booting from a Windows CD and run the Repair option in the setup.
Oct 20, 2009 | ASUS M51Ta-X1 NoteBook
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Eee pc 701 doesnt turn on
Make sure no external devices are plugged in.
If it's still under warranty you will have to return it.
Or take to an Asus support center as it seems to be a hardware problem.
Jul 13, 2009 | ASUS Eee PC 701 Notebook
Screen blank
Before switching on repeatedly press f9 while doing this switch on and then a boot menu should come up. Choose the 3rd option restore factory settings and go through the steps as guided.
Feb 28, 2009 | ASUS Eee 4G Notebook
DISPLAY PROBLEM
Check to see if your Video Card is bad by plugging the laptop into an External Monitor... then press the F5 key to toggle it to the external source...If your PC shows up on the second screen, you have video issues...
Jun 04, 2008 | Toshiba Satellite A135-S2276 Notebook
ASUS Eee 4G Notebook Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
