Question about Sony STR-DE975 Receiver
Sound lost At time of turning on receiver (TV and other inputs) sound is on.. After about 5 minutes sound off. Sometimes for at least 5-10 minutes. Then restored. About 15 minutes later goes off again. For about 5 minutes. Frequency of lapse of sound increasing. Hear a "click" when sound is lost. Some of the times I can restore sound by changing sound field. Is there any solution. What should I be looking for....dbrahinsky@pacificnet.net.
  • 1 more comment
  • slillestrand Sep 13, 2008
    I am having the same problem with the exact same model receiver. I hear the click as well and I can quick fix it by moving the TV input chords. I think there is a short some where, but obviousely this is a fixable issue.
    I need help as well on how to fix this.
    Thanks
    Scott
  • Anonymous Sep 17, 2008
    Had the same problem until a puff of smoke took the sound away permanently.
  • jmasters Dec 28, 2008
    I have the same problem with the same model. The clicking is coming from one of three relays on the main board inside the unit. I've "fixed" mine by smacking the side of the unit, which usually gets the relay to click back on. It doesn't always stay on. I don't know if it's worth it to replace those relays, or what. If you have the cover off of the unit, you can tap lightly on the relays (they are blue, and they're all together) and usually you'll hear and feel it click back on.
I don't know if this will solve your problem, but I have a question.  Does the receiver sit under another piece of hardware?  Especially one that gives off a lot of heat?  It is possible that the amp or power supply is overheating.  The heat forces the receiver off until it has a chance to cool down.  Then when it turns back on, it starts to generate heat again.  Try moving it out from under any other gear or out from under a shelf so that lots of air can get in the top.  Maybe even try putting a fan over it, just as a test to see if this helps.  I work at a recording studio in Toronto, and we were having the same problem with one of our digital multitrack tape machines (No the studio is not trapped 10 years in the past - we just use tape for backing up and client delivery).  Anyway, early in the day, the unit worked fine.  If we tried to use it later in the day, we would get glitches all over the tape, or the transport would freeze up altogether.  We found that when we moved the unit into a rack where it could really breath, and where it wasn't right under an 8 channel mic pre-amp, that it worked without any problem.  I hope this helps.  Good Luck!
Posted on Sep 18, 2008
Second level tv has a signal but the main tv on first floor has no signal.
Hello! It sounds like there are a few things that could actually be going on. If you are getting no picture on the TV(you have a black, blue, or snowy screen), you will want to make sure that the TV is on the correct channel and/or input. You will want to be on channel 3 or 4, and possibly on a Video 1 or 2 or HDMI 1 or 2 input. If that doesn't work, then try unplugging the receiver from the power source for about 10 seconds. If you are still not getting a picture, let me know!
If you have a signal loss message on your screen (Signal has been lost, Partial SIgnal loss, COmplete signal loss, or Acquiring signal), you will first want to unplug the receiver from the power source for 10 seconds. You will get the Acquiring singla message as the receiver reboots after you plug it in, but that should only be about 5 minutes at the most. If you get the message after 5 minutes, you will want to make sure that all of the cables going from the back of the receiver to the wall are tight. If that still doesn't do it, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Tx-sr606. Signal lost to TV on HDMI Out. Coming in from Component Video or DVD or Game Components. Audio is playing but I get no signal to TV. HDMI Cable is fine. usually have to turn it off or unplug...
Check the most popular solutions.Also check that if you give the receiver some time (in my situation at this moment about 10 minutes) after you turned it on an selection of source.
I just received the new capacitors from a German store and will install them 2 weeks from now.
Rgrds,
Phil
Jan 25, 2011 | Onkyo TX-SR606 Receiver
No picture with Yamaha 6130 reciever. have
The TV must be tuned to the correct input also. Please cycle through the tv inputs by pressing the input button on the tv one time, then wait 5 to 10 seconds for the tv to recognize the input signal. If nothing, press again. You don't say which tv you have but many newer models have 5 to 7 input sources you will have to cycle through to find your signal.
With out more information, this is just one step in finding out what could be wrong. Please rank me accordingly.
Good luck.
Feb 28, 2010 | Yamaha HTR-6130 Receiver
ADS DVD Xpress loses sound after 5-10 minutes
Check your inputs, I have posted this two other places - if using a VCR you have to set input to VCR/TV. Cheerio
Sep 08, 2009 | A D S DVD Xpress DX2
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
DVD video stops; audio continues
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Dec 10, 2007 | Pioneer VSX-D914 Receiver
No sound or picture
I'm not sure if you solved your technical issue or not, but if your TV is still broken, I would be interested in buying the door that covers the AV inputs. This door is on the front of the TV. Unfortunately, mine broke, and it's been difficult to find a replacement. If you are interested, I can be reached at (612) 801-5752 or by email at tremely@mac.com. Thanks.
Apr 07, 2007 | Sony KV-27FV16 TV
Set turns itself on for no reason (and sometimes off)
on menu, pick customize, then set the video input sensor to off.
Dec 31, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Sony STR-DE975 Receiver Logo
162 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
