Question about Xerox Office Equipment & Supplies
Currently own a 1988 Zerox XC830 copier, showing a L-4 error. What is this?
    President:
  • 2,072 Answers
L4 is a main motor problem. When you remove the rear cover it is left of center about mid way down the machine.
There are 4 screws holding it in, one power cable and a ribbon cable.
Remove it and see if the gear is cracked. Or the motor itself has failed.
You can google a business called "the parts drop". Look them up and call, ask for Britt, he can get you a motor for a reasonable price.
Posted on Sep 03, 2008
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
Ir3300 zerox is showing problem E000602-0003 what may be reason
Do you mean a Canon IR3300? This error indicates that the hard disk needs to be replaced by a Canon tech.
Jan 21, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon iR2016 zerox machin shows system error.E 001. How to rectify this problem please guide me.
these means that you have fixing trouble, probably low or high temperature.
You can clear it in service mode.If it doesn't help you need to change fixing heater.
press *
press 2
press 8
press *
By arrows navigate to CLEAR
press OK
navigate to ERR or ALL
press OK
Turn off and on
Hope that helps!
Notice that under my tips and tricks you have ir 2016/2020 error codes and how to clear certain codes.
Sep 01, 2010 | Canon iR 2016i Black and White Copier
My printer have a LSU Error so what i should do
check your printer inside for RAT damage,
this error ocured when lsu cable cuts by rat or LSU itself faulty
May 11, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Receive H 4 error code on zerox 1255 copier-nothing happens, the machine won't turn on-tried switching power of for 5 seconds nothing happened. Made sure the machine was pluged in a receptacle by its self,...
A H4 code is a problem with the fuser unit. That xerox is a Sharp copier. You may have a blown thermister or thermal fuse or a fusing lamp. You may need to repair the problem before you can clear it. I believe the code to reset it is in service mode SM 16
Mar 12, 2010 | Office Equipment & Supplies
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
