When installing program an error message appears, error 1719 windows installer service could not be accessed
  • 659 Answers
Error 1719. The Windows Installer Service could not be accessed. You may be running in Safe mode or Windows Installer may not be correctly installed
please goto the following link for a fix for this issue.
http://support.microsoft.com/default.aspx?scid=kb;en-us;315346
Posted on Sep 03, 2008
I need help to Access my Poser 7 Program that I just purchased and that I just finished installing on my Windows XP Computer. Can you please help me to gain access to my Poser 7 Program please?
If the Poser 7 program installed correctly without any error messages then to access this program then -
Click on Start - All Program and click on the Poser 7 program to start the program.
Apr 06, 2012 | Computers & Internet
I try to install the software and get this Error 1719: Windows Installer could not be accessed
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
or you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
Jan 13, 2011 | LG Computers & Internet
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
Vista window installer cannot be accessed/incorrectly installed for some downloads
Start the Windows Installer service
  1. Click Start, type Services.msc and press {ENTER}
  2. Double-click Windows Installer
  3. Set the Startup type of Windows Installer to Manual
  4. Click Start to start the service. (Write down the error message if any).
  5. Click OK.
Windows Installer Registry Fix If the above steps do not help or if the Windows Installer service is not listed in the Services applet, follow these steps:
  1. Download msiserver.zip and save it to Desktop.
  2. Unzip the file and extract msiserver.reg to the Desktop.
  3. Right-click msiserver.reg and choose Merge.
  4. Click Yes when asked for confirmation.
  5. Restart Windows.
May 27, 2009 | HP Pavilion a1610n PC Desktop
New application software can not installed
I SOLVED THIS ON MY LAPTOP BY REINSTALLING THE WINDOWS INSTALLER. THIS PROBLEM USUALLY HAPPENS WHEN THE INSTALLER IS CORRUPTED BY SOME MALFUNCTION. THE BEST SOLUTION IS TO UNINSTALL AND RE-INSTALL THE PROGRAM FROM THE MICROSOFT WEBSITE. HOPE THIS HELPS YOU.
ARCLIGHT1217
Nov 03, 2008 | Microsoft Windows XP Professional
Error 1719
Error 1719 occurs when the msiexec.exe program becomes disassociated with .msi files. Under Windows XP x32 this is usually fixed with rebooting into safe mode, renaming the msiexec and DLL's and letting Windows File Protection reinstall them. This doesn't always work in x64.
Error 1719 occurs in x64 when the 32-bit version of msiexec is registered as the msiserver. Here's the fix:
  1. Open regedit ( Start -> Run -> regedit.exe -> OK)
  2. Go to the following key: My computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  3. Look at the ImagePath entry. For Windows XP x64 it should read:
CODE - C:\WINDOWS\SysWOW64\msiexec.exe /V
If it doesn't edit the registry to match that.
4. Restart the Windows Installer service from the Admin Control Panel -> Services CP
OR
Click on the below link or copy the URL and paste it in your web browser.. Follow the steps....
http://support.microsoft.com/kb/315346
Thank you......
Oct 01, 2008 | HP Computers & Internet
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
