Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Engine 2003 harley missing
Changed plugs wires coil cleaned carb
Could also be a crank position sensor if a late model bike. make sure power is not sporatic.(depends upon model) the power flows from ign sw. through a fuse or cicuit breaker (circuit breaker could have intermitant contact) then to handle bar sw. which could have the same problem, then to the bank angle sensor which could have the same problem and finally to the ign module. hey, pyrhyc, what is a jet seat? (what a fighter pilot sits in?) a jet is just an orfice, which i agree could wear but if it does, a rich mix will not miss. it will usually cause sooty plus or black smoke from the exhaust. if too rich, the bike will bog out and/or quit running. a lean mix will cause a misfire. if you are talking about the mix needle, it does not seat in the carb, it only controls the amount out fuel that slips though the main jet until wot. screaming chicken is a good module but i would not buy them when aftermarket is much better. unless it is strickly race, big brother still has his fingers in it and limits the full potential of the bike. higher revs are ok but there are other mods that need to be done before going there. the number one hold back is hd hydraulics. they are good for a stock setup only. there are cheap ways around this and then there are expensive ways are this.
Posted on Sep 07, 2008
    Genius:
  • 2,028 Answers
Without being able to hear the miss, I'm going to have to give you a couple of different solutions, and you'll have to figure out which it is.
1- is going to be a spark miss. Since you've done the plugs, wires, and coil, the only thing left is the ignition module. Check and clean the connections for the module, and check all wires for any bare spots, dry-rot, corrosion, breaks, or a loose ground. If you're getting a weak or sporadic spark, any of these could cause it, or the module could be going out. If you change out the ignition module, I recommend using the Screamin Eagle or an after market module with a hotter burn and higher rev limiter for better performance.
2- is going to be a fuel miss. It could be that the jets or the jet seats are worn, and that you're getting slightly more fuel than what it's set up for. It's generally the jets that get worn, and rejetting the carb will fix it. This eventually happens with all carb models.
I believe that it going to be one of these two, and it may be time for upgrades anyway. Upgrades are always cool. Anyway, let me know how this works out for you.
Posted on Sep 03, 2008
No spark to plug
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
For a primary suspect please visit the website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Good luck
Feb 24, 2014 | 2003 Harley Davidson FXDL Dyna Low Rider
2003 harley davidson road king cranks but will not start
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Nov 13, 2013 | 2003 Harley Davidson FLHRCI Road King...
2003 has miss while riding at asteady speed
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Jun 02, 2013 | 2003 Harley Davidson FLHTCUI Electra Glide...
Harley davidson 2003 flstfi wont start up
1. Fuel tank empty
7. Discharged battery, loose or broken battery connections especially the negative cable at "BOTH" ends
For a primary suspect please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Nov 19, 2012 | 2005 Harley Davidson FLSTSC - FLSTSCI...
2003 Harley Electra Glide Ultra cranks but won't start. Changed coil and plugs and it started right up. Drove 100 or so miles and now it just cranks and won't fire.
Hi Gloriane, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Jun 18, 2011 | Harley Davidson DNA 50 Motorcycles
Changed fuel pump on 2003 flht ultra classic. Ran fine. Went to start bike couple months later now it wont start again. drained all gas put some cleaner and new gas in it. still nothing?
Hi Rustedwrench, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Sep 19, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
I have a 2003 fuel injected fatboy.. Where is the fuel vacuum line. Bike turns over but will not run.
Hi Cartercg, the fuel vacuum line is for carburetors only, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley... Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Aug 25, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
Engine turns over does not start there is no spark at plug 2003 hd fxstdi
Hi Ggmoor2, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Apr 20, 2010 | 2003 Harley Davidson FXSTD Softail Deuce
2003 HD Fatboy has a miss. New plugs and wires.
i take it its carb. after it warms up to operating temps does it stop the sputtering? thats just a HD CV carb doing what it does til hot. Im not talking a 2 min warm up and off u go im talking operating temps of 200 plus. Is the carb an S&S? Your going to have high rpms til the temp kicks it down if its injected
Oct 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
447 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
