Woods 59208 is single-pole timer.
Open following link to see list of timers used for 3-way application:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
When replacing 3-way switch, some timers can replace either switch. For example Aube and GE.
Other timers can only replace switch that receives power from breaker. For example Intermatic.
The timer replaces only 1 of the 3-way switches.
The other 3-way switch remains.
But in all cases, the remaining 3-way switch has to be rewired to accommodate the timer.
3-way timers cannot replace 3-way switch wire-for-wire.
3-way timers mimic 3-way operation. When 2 of the timer wires are
connected, the timer reverses programming. When those two wires are
disconnected, the timer programming resumes. So off becomes on, and on
becomes off.
The remaining 3-way switch has to be rewired so that switch connects and disconnects the two timer wires that mimic 3-way operation.
http://waterheatertimer.org/Woods-59028-59018.pdf
To save manual to your computer > click link above and let page fully open > go to File at top of browser > click save-as.
To print manual > open page > go to File > click print
Programming cannot take place until timer is wired correctly and power turned on. This is because clock motor inside timer runs on 120V circuit:
Timer has 4 wires
Black wire from timer connects to black hot wire from breaker box
Red wire connects to black wire going to load (lights, fan etc)
White wire from timer connects to white neutral from breaker box ((if no neutral is available, then connect white wire to bare ground wire)
Green wire connects to bare copper wire
To see sample of wiring when white connects to bare copper
http://waterheatertimer.org/images/EI210-wiring-full.jpg
