Question about Air Tools & Compressors
Central air unit leaking water?
I have a central air unit that has begun to leak water again. A few months ago, someone came out and told me that it was clogged with algie, and he put algie tablets in it, and instructed me to put bleach in that line every now and then, I have done it but it has begun to leak again, what do you suggest I do from here?
Please Help!
  • 50 Answers
My guess is that water is accumulating in the tray or line, and not draining properly. To fix it, you will need to tip the tray so that no water accumulates. Also, check if the line is draining. Good luck.
Posted on Feb 04, 2009
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
A month ago my a/c started to leak water.We called help & they pumped the tubes then they put freon,they said the leak is on the unit not inside the house,it worked for a week then the a/c stopped...
Could be leak on your indoor coil and they missed it. Call them back ask them to leak check inside. If they missed it it is their rsponsibility. to repair. Rus
Jul 19, 2009 | Heating & Cooling
Central AC unit not cooling
If you have access to your piping system you may use a soap bubbles to test the pipe connection. the leak gas will blow the bubbles if there is leaking. But if your system is out off freon gas, you can not use this method. just try it check the connection first put the bubbles around it.
Jun 04, 2009 | Heating & Cooling
Unit leaking
leakage from my central air unit from drain pan, please help
Apr 29, 2009 | Whirlwind FH-778 Air Conditioner
61 Gallon Rheem Water Heater is leaking!
TANK COULD BE LEAKING BUT NOT USUALLY @ TOP CK ALL FITTINGS VERY CAREFULLY AND BE SURE IT IS NOT ONE OF THEM
Feb 21, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Random "Cracking" Noise
Its refrigerant gas has leaked out so ice is forming on the evaporator which breaks and causes this cracking sound. The same is resulting in less cooling as well. Get the refrigerant gas pressure checked and fixed.
Jul 15, 2008 | Maytag Chassis Built-In Air Conditioner...
Leaking water; reservoirs empty
I have this too we had that problem as well, nothing we could do about it either..
i need a new hose and exaust kit you know anywhere to get that?
this unit is ancient
May 22, 2008 | Danby DPAC7599 Air Conditioner
Dometic roof top air-con trouble
1.check wiring of unit.
2.check drain tray.
3.check u band of drain pipe.
Feb 16, 2008 | Dometic Rooftop RV Air Conditioner
Ruud Hot Water Heater
I suspect there is a leak in the tank and because you shut it off for a period of time, the hole sealed up with rust. If the heater is under warranty, contact your installer and show him the water spots inside the jacket. It should be covered under the warranty. If it is out of warranty, replace it before it does damage to the surrounding areas. If you let it go a while, get yourself a moisture alarm and put it next to the unit. If it should leak again, it will not stop until someone turns off the water valve. \\Good Luck!
Jul 27, 2007 | Ruud Central System Air Conditioner
Bloomfield 8572 Leaking
I just repaired my Bloomfield 8543 unit. I removed the top, by first removing the top rear 2 screws and unplugging the 2 heating element wires under it. Then mark all the wires that go to everything, (it is only a few) remove the center screw that holds the water tank lid brace down, slid the brace to one side (the groove on one side is longer) and remove the brace. (My brace was bent.) Then lift the lid (the heating elements will come with it) and clean the gasket. I went as far as to remove the tank, clean that as well as all the tubes. I tightened everything down and it worked perfectly again. Good luck, ken
Jul 31, 2006 | Bloomfield 8572 Coffee Maker
Air Tools & Compressors Logo
2,606 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
