The red color is out of alingment,it canot be adjusted withe the remote
  • 8,617 Answers
You need to replace the convergence Ics. Please respond to this same post with your model number and I will try to assist you with the correct Ics for your model.
Posted on Sep 03, 2008
The color adjustment won't work. I click on it and go down on other adjustments but none will open to adjust the colors.
you can buy a universal remote for 1 dollar.. option 1 however if you are using componelt input as in RGB then you have no control over your colors
Oct 07, 2014 | RCA P52927 52" Rear Projection TV
Red picture tube out of alingment how do you make major adjustment
Its done with the original remote--convergence in the customer menu should be looked at first---call up the crosses or the grid of lines, it has one or the other.
You first want to look to see if red out and then if it will move both up/down and left right where off.
If it will not move in some direction anywhere on the screen the convergence output chips the set uses are bad.
The set will or should have two hidden menus, one will bring up the advanced grid for convergence---input for that with the remote is Mute, 181 or 183----if you call up the wrong one shut set off and try the other number.
It is possible to converge the whole screen there, if memory serves me 7,8,9 change the color being adjusted DO NOT ADJUST GREEN FOR ANY REASON.
two buttons (different on different remotes will move the cursor around the grid (and the remote must have a button somewhere on it with "data" to save the adjustments.
Check in customer menu the convergence first---got movement?
Dec 08, 2012 | Samsung HLP5685W 56" Rear Projection...
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
Covergence problems or alingment , its has three colors without alingment please help me!!!
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Apr 29, 2010 | Zenith R57W46 57" Rear Projection...
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
All in one Lexmark X1270 printer
check your printer color setting  and adjust the color that you need second calibrate your printer third is check your cable or usb cable 4th check the website for new drivers update.........thats it!!
Sep 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red convergence out of alingment
If you cant adjust it with the convergence option on the menu you will need new ICs. They are inexpensive. I can post a link where you can get replacement ICs and free step by step instructions on how to do the repair yoursel. The Conversion ICs will have STK numbers such as STK392-110 or simallar There are two of them identical attached to a large heat sink.
Mar 30, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
Top Televison & Video Experts
