Question about Sony ECM-MS907 Professional Microphone
Left channel only
My Sony mic ECM MS907 used to work without a problem, but now seems to only record through the left channel. I use it with a Sony mini disc (MZ RH910) - I have used other mics with the mini disc player, so I know that the problem lies with the mic.
I'm wondering if it's possible (and/or worth it) to fix the mic (and how to go about doing that), or should I be purchasing a new one?
  • 20 Answers
If you take it to a store then you can probably have it sent to sony who will give you an estimate before fixing it. This mic offers one of the best cost performance ratios so you will probably end up buying another one. Upon that assumption, ifthe repair quote is less than about 70% of the retail price then it may be worth getting it repaired. I have found sony repairs (to a digital camera) to be reasonably priced.
Posted on Oct 17, 2008
I'm looking for a replacement wind shield for a Sony ECM-MS907 microphone. Does anyone know of a store that stocks them? The cover that is, not the mic, I have that! :-) Thanks in advance! psibernaut ...
Radioshack has some generic windscreens, call ahead though as sometimes they are buried in the back room. You can also make one using panty hose. Kind've DIY but good in a pinch.
Mar 01, 2011 | Sony ECM-MS907 Professional Microphone
Hi, I bought a sony ecm mic brand new, but whenever i switch it on, the red light comes on for a fraction of a second and then goes off, and i cannot record with it. This is despite trying many new...
Ah, yes.
If you look in the manual you'll find that the mic is supposed to do this.
If the LED does not blink when you switch on then you have a flat battery, otherwise it shouldn't stay lit.
The manual is available here in PDF format:
I hope this helps.
psibernaut >;-)
Oct 24, 2009 | Sony ECM-MS907 Professional Microphone
When i record my vocals its only in one channel why!
It seems that the recording input source is provided as "Line In" whereas you need to select the "Mic In".
This is because the "Line In" is a stereo input and expects input for both right and left channels whereas the "Mic In" input is a mono input which is the same as our default condensed mic device is.
By the way, you would be able to see the graphic VU meters while recording, weren't they displayed that the recording is done only for one channel ?
Always use VU meters for checking the levels for recording, they are available with almost all recording softwares.
Hope this helps.
Mar 31, 2009 | Sony Acid Music Studio 7 Full Version for...
I have an ECM-MS907 Sony mike. I started having some issues with a wierd buzz and then I realized that my cord was frayed. Is there anywhere I can get a replacement cord? The issue I see with replacing...
I had a similar problem with my ECM-MS907.
The cable had broken near the mic and the right channel would drop in and out as i moved the cable.
Unfortunately the only solution is to open up the microphone, unsolder the cable, cut out the broken area and solder in the remainder of the cable.
I did this this morning and it was quite tricky. It's easy to open the microphone (3 screws) and the 3 solder pads (left, right and ground) are large and easy to solder to. The big problem is that the wires for left and right channels in the cable are very fine and insulated with enamel which is hard to strip (try just burning it off with the tip of the soldering iron).
Anyway, a bit of an involved fix... I wish this mic had a 3.5mm socket on the bottom  instead of having the cable soldered in. I hate stuff that's not easily replaceable.
Dec 09, 2008 | Sony One-Point ECM-MS907 Consumer...
Should the light come on!?
Hi timtak
The light should come on momentarily when you turn the mic on, and then go out. If it remains dimly lit, or does not come on at all, then the battery needs to be replaced. The way the light responds is supposed to indicate the condition of the battery for you, unless it is so depleted that there is not enough juice left to light the LED. You can read up about this in the user manual here if you want:) A FixYa is a great reward for sorting this out for yah. Cheers
Oct 17, 2008 | Sony ECM-MS907 Professional Microphone
IT DOES NOT WORK ECM-MS907 Professional...
Just in case you have having the same problem as me....
The reason why my microphone was giving mixed results was because I was using the wrong setting. The microphone slider says "90 degrees" and "120 degrees." I assumed that these angles refered to the area that the microphone picked up. So for a single narrow sound source, like my voice, the narrower, 90 degrees setting seemed appropriate.
Now that I have looked at the manual I see it is the reverse (weird but true. Perhaps the angles refer to the angles that the microphone ignores completely under each setting?).
I have been recording my voice. I noticed that sometimes the sound was good and other times the sound level was too low. I think that the reason is because sometimes I inadvertantly set the microphone to the 120 degree setting, which picks up my voice well, while at other times I set the mic to the 90 degree setting which attempts to pick up sound from a wider area, giving the central source less prominence.Setting the microphone to the 120 degree setting cured my problem. I hope it cures your problem too.
The manual is here:
Aug 24, 2008 | Sony ECM-MS907 Professional Microphone
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Problem recording in stereo
Most likely you have a problem with the MIC. Has this ever worked with this unit? If not maybe the un it is not compadable with this Mic. The instuctions and specs are available for download Here Good luck
Jun 12, 2007 | Sony One-Point ECM-MS907 Consumer...
Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Apr 13, 2007 | Sony One-Point ECM-MS907 Consumer...
Sony ECM-MS907 Professional Microphone Logo
170 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
