Question about Toshiba 46HM95 46" HDTV
COLOR WHEEL MOST LIKELY
THERE IS THIS LOUD GRINDING NOISE AND THE PICTURE ISN'T CLEAR AT ALL.
  • 2,071 Answers
Just click below for more information ;
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Hope this may help you;
DON'T FORGET TO RATE;
Posted on Sep 03, 2008
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Loud noise and no picture ON DLP model HLR5668WX/XAA
If it is a high pitched whine or a grinding sound it is a bad color wheel.
Not real difficult to determine and replace.
Let me know if I can assist you.
SD TECH
May 26, 2010 | Samsung DLP HL-P5663W 56" TV
Loud grinding noise when the lightbulb is on
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming ,grinding,buzzing noises.
Apr 06, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Samsung DLP HLR5667wx/xaa. All sudden loud noise non stop
This sounds like you may have a bad color wheel. If you want to change this yourself you need to be aware that even with the tv unplugged there are still dangerous voltages in the set.
Changing the color wheel is an involved repair the wheel it's self is very fragile to handle, they can be purchased on line from many sources.
The cost from a service center would be a normal service charge plus about $150.00 for a color wheel. If you have a service center come out to your house explain your problem clearly and they will know they need to bring a color wheel, it will prevent the tech from having to make a second visit.
Sep 05, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Jul 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Dec 13, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Toshiba 46HM95 46" HDTV Logo
143 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
