Question about Photography
Fuji discovery 2000 zoom
I just need some general information how to turn it on and take pictures i got the camera used and the batteries work just fine and i have film for it but i am unable to load the film please get back to me soon as i need this for a college course that starts in a half an hour
Www.orphancameras.com there are a few Fuji discovery camera manuals there.
Posted on Sep 07, 2008
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.
Problem is fixed and focus now working ok.
Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error
Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start working. I need to make small adjustment . Reason when camera is started picture is not clear and before using camera i need to do full zoom in and back zoom out. After this picture is crystal clear and all working ok.
Dec 17, 2012 | Fuji FinePix S304 Digital Camera
My Fuji finepix 2800z uses batteries up in seconds. Works fine otherwise and is ok with DC. Shame as it is such a good camera. Any ideas why and if it can be fixed? Thanks
Wow, these cameras work the best with rechargeable type batteries the Alkaline batteries will just die before you get 50 pictures. If you are using the LCD screen all the time it's a power hungry hog and will kill the best of batteries quickly.
You should program the camera to auto shut off in 2 minutes, review time should be about 1 minute and the camera should be in sleep mode or turned off between pictures to conserve as much power as possible.
I use a Fuji S100fs camera a lot for a walk about, documentary, time laps and generally shooting and can get about an hour of continues use from one battery and about 190 frames.
Apr 19, 2011 | Fuji FinePix 2800 Zoom Digital Camera
Is there a manual available for the Fuji Discovery 1000 Zoom camera? Also, where can one purchase film for this camera.
You can download the manual at
http://www.cameramanuals.org/fuji_pdf/fuji_discovery_1000_zoom-1.pdf
The camera uses standard 35mm film. 35mm film is available in black-and-white, color negative (print) and color reversal (slide) forms (and others). 35mm film should be available at any camera store, as well as many drugstores and even supermarkets.
Jan 09, 2011 | Fuji Discovery 1000 35mm Point and Shoot...
I can't get my fuji discovery 1000 zoom to read film
A camera is for recording images onto film, not reading the film.
Jul 18, 2017 | Fuji Discovery 1000 35mm Point and Shoot...
The dreaded zoom error
This generally occurs when the camera has been dropped or banged around.
You'll either have to get it swapped from point of purchase, or you will have to take advantage of the manufacturer's warranty.
Apr 03, 2008 | Fuji FinePix A340 Digital Camera
Zoom Error
try to manually adjust the zoom. My camera is doing the same thing. sometimes I can get it to focus after forcing the camera to zoom in and out a few times. No one well let me know how to get hold of a repair manual to adjust this, but when I figure it out I will post it.
Dec 14, 2007 | Fuji FinePix A345 Digital Camera
Fuji Film Question
The easiest way to tell if camera shake is the problem is to use a tripod - generally not necessary on a bright day, at least with my camera (also a 10x zoom). If a tripod doesn't give you clearer pictures then camera shake is most likely not the problem; if it is, either use a tripod for your big zoom shoots or get used to bracing the camera, either just with your hands held out from your body or against a wall / post / anything handy. Good luck!
Sep 04, 2005 | Fuji FinePix S5100 Digital Camera
Photography Logo
161 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
