There is a hole somewhere in our outdoor coil on ac and it leaked out all freon. it is nordyne intertherm manufactured home ac. 1998 can it be fixed.
  • 3 Answers
Yes it can be fixed but you need to have the equipments like freon and the you need to fill the leakage thank you
Posted on Sep 03, 2008
Intertherm 2312 0r 2512 wiring diagram
http://enora.nordyne.com/Literature/Resarchive.asp#SP AC
Copy this link not sure why the Ac part at the end isn't attached to the link but it is part of it.
Should be able to find any wiring diagram for your Intertherm Ac, which is manufactured by Nordyne.
Hope this helps.
Feb 26, 2013 | Intertherm P3RA-048K Air Conditioner
I am trying to get some information on Intertherm unit on the inside of a Manufactured Home, With the new Hud requirements they are saying the out door unit must be installed by the manufactures...
Hi, since you live in a Manufactured home and not a R.V., I see no reason why you cannot go with what ever type of condensing unit you want to install on a slab outdoors. The installation instructions for the Intertherm unit for installing the outdoor unit should apply to any brand unit you want to use as long as the size of the indoor coil is the same capacity of the outdoor unit. For example, if the indoor unit is a 2 ton, 2.5 ton, 3 ton and so on, the outdoor unit would have to be the same is all. Same freon type, most are R-22, but they are using the new R-410a freon, so make sure of the freon type of the indoor coil is and get a unit of the same size and freon type. The installation instructions for the Intertherm should almost be the exact way to install any other condenser. Look for things like the distance from the outside wall, if it needs to be anchored, how far away the electrical disconnect box has to be from the unit, example 4' to 6'. Things like this you need to look for in the installation instructions is all. The new condenser unit holds enough freon for up to 25' of copper line set also. Try to stay with in that range to the indoor unit. If not, no big deal, they may need to add or remove a little freon is all. I hope this has been helpful to you on this. Trane, Carrier, Rheem, Ruud, Bryant, are all top of the line, better made then Tntertherm in my opinion. They should all be hud approved, I don't know where you are from, but here in Ca, they are.
I wish you the best, and please don't forget to rate me. I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Aug 06, 2010 | Intertherm Heating & Cooling
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
We have a Intertherm Nordyne heater/airconditioner. New, we just moved into a mfg home. The air is really loud, is there a fix for this. Someone suggested we get a different squirrel cage...
Theres all kind of answers.. close off the return grill and re route the return air system, get anouther unit, Have the realator to fix this problem or give you an adjustment, and you do it your self, ask a reputable ac man..ect, ect,,!
Sep 06, 2008 | Heating & Cooling
I need a coil for a split unit intertherm unit I dont know the model but the moble home is a 1998
That's not going to cut it. You can't just stick a coil on a system. You will need model # of furnace and most importantly the model # of the outdoor unit in order to find a coil that is an appropriate match; otherwise, you will probably end up shooting yourself in the foot and spending alot more in the long run to fix mistakes. I recomend contating a local professional to help you.
Jun 24, 2008 | Intertherm Heating & Cooling
Fair price to fix central air conditioner leak & refill with freon
I have heard that there is a spray you can use that will not damage your system and seals the leak when it comes in contact with oxygen
Apr 18, 2008 | Heating & Cooling
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
