Question about HP LaserJet 2550L Printer
Hp color laserjet 2550L printing problem
Green light steady on horseshoe shaped symble. Printer will not print.
  • Anonymous Mar 19, 2014
    printer wont print
    President:
  • 4,402 Answers
Posted on Sep 03, 2008
What does the horseshoe shape green light mean on a hp laserjet p1102 printer?
If that light is permanently lit and it's the only one that's lit, it means that the printer is online and everything is OK. If that is the only one blinking, it means that the printer is receiving and processing informations from the computer.
Jun 29, 2011 | HP Office Equipment & Supplies
I have agreen light by symblom that looks like a
I think that is just the indicator to let you know the unit has power, and is on when the green light is lit.
Jun 17, 2010 | HP LaserJet 2550L Printer
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Oct 02, 2009 | HP LaserJet 1320n Printer
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
2550Ln will not print
If the supply lights are not lit, then you may have a paper jam. Check the rear cover. Also sometimes paper jam lights come on even though the paper has not jammed, just misfed from the cassette. Please let me know any further details.
May 12, 2009 | HP LaserJet 2550L Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Jan 15, 2009 | HP LaserJet 4600dn Color Printer
Zebra LP 2844
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Feb 28, 2008 | Zebra LP 2844 Thermal Printer
HP LaserJet 2550L Printer Logo
328 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
