Question about Refrigerators
Sub zero 532
Problem with the freezer side not gettin cold enough
  • 763 Answers
Try this link it might be helpful to your freezer
dont forget to rate my post at the previous post. thanks!!
Posted on Sep 03, 2008
Freezer fan not working - Sub zero 532 -
usually this is because the fan is clogged with ice and has frozen ice stopping it from spinning otherwise if you see no ice blocking the fan from spinning see the link below and purchase new fan and replace it.
Sub zero 532 fan Google Search
Feb 16, 2018 | Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
Sub zero 611 refrigerator error code 40, freezer will not get cold enough but refrigerator compartment working
code 40 compressor for the freezer side over runing. check the coils upper part of the unit. or condenser fan motor. easy things to check.
Mar 18, 2010 | Sub-Zero Bottom Freezer Refrigerator
Model 532 freezer will not freeze
Check a Condenser, if it dirty and full of dust and lint - clean it with soft brush vacuum, it's behind the grill with Sub-Zero logo on it. Right hand side usually
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 532 freezer
Confused: you say the temp. won't go UP! Are adjusting it the wrong way possibly? Check your users manual on procedure. Make sure nothing is preventing proper doors closing and not sealing properly,
Dec 24, 2017 | Freezers
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
