Printing envelopes from gestetner 3502P
Windows XP trying to print envelopes from word 2000. I need to set up first before i can do anything else. Please help!!
Thanks for trying but We are having this problem with the envelope comes out of the printer but with nothing on it.  Then the printer jams.
Posted on Sep 03, 2008
  • 2,794 Answers
What size are the envelopes?
Envelopes have to be fed through the bypass. #10 envelopes are not recommended to run through the copier. There too small to feed through the fuser rollers and they will jam.
Scan to file on DSc525
The smb version on windows 7 is new than the one on XP. You will need a firmware upgrade.
Jul 29, 2013 | Gestetner DSc525 All-In-One Laser Printer
Printing envelopes
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
My lexmark will not print envelopes. IT will print labels. Does this have anything to do with Windows &?
Both my Hp1220 (which is pretty old) and my Epson C62 will print envelopes,so I'm sure yours will. You need to go into the print preferences (possibly advanced) and set the SIZE,not paper type to the size envelope you need to print.I have the options of #10,DL & C6.
I think those are the standard sizes.
Let me know.
Aug 09, 2010 | Lexmark Z705 Inkjet Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Printing DL envelope on Canon Pixma iP4600
    its not the problem of your way of operation, its the limitation of of the printer.
    Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
    Toshiba 281C Bypass tray
    Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
    Feb 17, 2009 | Toshiba Estudio 200L Copier
    Can't print envelopes
    Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
    thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
    Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
      1. Under the Tools tab, select Envelopes and Labels.
      2. Enter your Delivery and Return addresses.
      3. Click on Options
      4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
      5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
          • As Feed from, select Tray 5 (Bypass)
      6. Click <OK>
    Within the WorkCentre Pro 123/128 print driver
    After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
    • Under the Paper/Output tab
    Set the following features as follow:
      • Job Type: Normal Print
      • Paper Size: COM10
      • Output Size: Same as Paper Size
      • Image orientation: Portrait
      • Image Rotation: OFF
      • 2 sided Print: 1 sided Print
      • Stapling: None
      • Output destination: Center Output Tray
      • Offset Stacking: None
    • Under Tray/Layout
    • Set Paper Source to Tray 5 (Bypass)
    • Click on Bypass Tray Settings
      • Paper Type: Heavyweight (1 or 2)
      • Feed orientation: Portrait
    • Click <OK>
    • " on Specify Paper Type and select Heavyweight (1 or 2)
    • " (Apply> and <OK>
    • " <OK> again
    In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
    Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
    Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
    Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
    137 people viewed this question
