Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Dishwasher fuse in plug keeps blowing, i use it every day and it blows at least twice a week
  • 2,071 Answers
There is a short there, in control panel circuit board,that's why your fuse is keeps blowing.Trace the electrical connection from down to up to control panel board. Check for short capacitor and diode..Feel free to ask whatever the result..
Hope this may help you;
DON'T FORGET TO RATE;
Posted on Sep 03, 2008
2006 Mitsubishi Lancer, gauge fuse keeps blowing. Have replaced the fuse twice, first time it was fine for a week but now it blows after a few minutes of driving...anysuggestionso
I would normally say to replace with a higher amp fuse, from a 15 to a 20. But it's possible you have a short somewhere in your system, grounding a power wire. A higher amp fuse could cause that grounded wire to overheat and burn making smoke. First thing to do is to check the ground wire(white)where connected to the firewall under dash and make sure they are clean and tight, for a good connection. The power may be backfeeding and causing the fuse to pop because of a week ground.
Dec 01, 2014 | 2006 Mitsubishi Lancer
Fuse for horn keeps blowing on outlander 2007
Someone will need to troubleshoot the circuit to find the short to ground.
Could be in the wiring or the steering wheel.
Oct 02, 2012 | 2007 Mitsubishi Outlander LS
It keep blowing up the fuse on pcb ***,y main power supply, we have changed the board twice , first time it worked for a week and second time for 2 hours before blowing up the fuse and probably the board,...
There must be another component which is causing this to happen IE/ The compressor, capacitor, fan, reversing valve coil or perhaps it may just be a damaged wire shorting somewhere. You will hav eto go through each component with an electrical test meter to ascertain which one is faulty... Good luck. Until then , i wouldnt go out and buy another board...it will blow that one as well...
Jul 13, 2011 | LG Heating & Cooling
Hi can you help i have a Saab 93 2.0LT 04 the windscreen washer keep blowing the fuse i have replaced it twice with no luck thanks jim
the fuse is telling you that something is drawing too much current through its circuit, making it blow out. to protect that circuit is its function. disconnect the electrical plug from the washer motor and put a new fuse in. if the fuse still blows out then your problem is something else shorted out in the circuit, and you should look at the legend to see what else shares that circuit. if the fuse does not blow out then you should get yourself another washer motor.
Dec 12, 2010 | 2004 Saab 9-3
Engine management fuse keeps blowing
My car stopped running without any warning, its a 2005 ford focus, 2.0 and the 20 amp fuse for the engine management keeps blowing, it's number 9 in the panel and I have replaced it twice, both times it blew again, any tips? Also the odometer reads ------ and that's it.
Jan 09, 2010 | 2001 Ford Focus
Blowing engine control fuse on 94 grand cherokee
You might have a wire from the engine control circuit that has rubbed through on the engine block somewhere. Do a visual inspection of the engine wiring, and look closely for any damaged insulation. I have seen a problem like this before. Good Luck!
Sep 28, 2009 | 1994 Jeep Grand Cherokee
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
920 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
