Question about Sub-Zero Refrigerators
Sub zero 532
Freezer is no getting cold enough.
when i adjust the T-STAT knob it does not click or seem to kick up the temp?
I had the same problem on the reefer side...it was a bad t-stat...i cost me $400 for a 5 minuite fix .
Any suggestions?
  • 3 more comments
  • bobbparts Sep 03, 2008
    problem on freezer side not getting cold enough
    fridge side is getting cold
    is the s-atat on the freezer maybe bad.
    no click when I move the dial
    compressor is running
    yes it was ...
    Master:
  • 521 Answers
Its the problem of T-STAT but before replacing the T-STAT please get the other parts or the circuit board checked because something is short in the board so the T-STAT is been affected both the times.if you will directlt replace T-STAT there are chances it may go faulty again after some days due to short tracking.so reparing that shorttracking before replacement is very much necessary.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
    Genius:
  • 3,422 Answers
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
Thecompressor is a football-sized case with no apparent moving parts. It'son the outside of the refrigerator at the back near the bottom. If itis humming or making a continuous noise and your refrigerator is stillnot cooling, there may be a more serious problem with one or more ofseveral different components, we recommend contacting a qualifiedappliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor Foran overall understanding of how refrigerators should work, read aboutrefrigerators in the How Things Work section of our website. Arefrigerator or freezer that is cooling, but cooling poorly, may have aproblem in one of several areas:
Evaporator coils
Condenser
Poorcooling is often the result of a heavy frost build-up on the evaporatorcoils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poorcooling is often the result of a heavy frost build-up on the evaporatorcoils. You can't see these coils without removing a panel on the insideof your freezer. A sure sign that there is a build-up is the presenceof any frost or ice build-up on the inside walls, floor, or ceiling ofthe freezer. Such a frost build-up usually indicates a problem in theself-defrosting system or damaged door gaskets.
The refrigeratoris supposed to self-defrost approximately four times in every 24 hourperiod. If one of the components in the self-defrosting system fails,the refrigerator continues to try to cool. Eventually, though, so muchfrost builds up on the evaporator coils that the circulating fan can'tdraw air over the coils. There may still be a small amount of coolingbecause the coils are icy, but with no air flow over the coils, coolingin the refrigerator compartment is quite limited.
Here's aninexpensive, though inconvenient, way to determine if the problem iswith the self-defrosting system. Remove all of the perishable food fromthe refrigerator and freezer, turn the thermostat in the refrigeratorto Off, and leave the doors open for 24 to 48 hours. (Be sure to haveseveral towels ready in case the melting frost and ice causes the drippan to overflow). This allows the refrigerator to defrost "manually."When the frost and ice build-up has completely melted away, turn thethermostat back to a normal setting. If the refrigerator then coolsproperly, it indicates a problem with one of three components in theself-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
Ifit still does not cool properly, there may be a problem with therefrigerant level or the compressor. You may need to consult with aqualified appliance repair technician to further diagnose the problem
Condenser Self-defrostingrefrigerators all have a set of coils and a cooling fan, usually underthe refrigerator, that need to be cleaned regularly. If these coils getcoated with dust, dirt or lint, the refrigerator may not cool properly.The coils may appear to be a thin, black, wide radiator-like devicebehind the lower kick-panel. To clean them, disconnect the refrigeratorfrom the power source, use a refrigerator condenser brush (see theAppliance Accessories section) and your vacuum cleaner to clean thecoils of any lint, pet hair, etc. You may not be able to get to all ofthe condenser from the front, it may be necessary to clean theremainder of the condenser from the rear of the refrigerator.
  • Priya darshan Sep 03, 2008
    Please don't forget to accept the solution.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR REFRIGERATOR?
sub zero 532 - small_4_1.jpg For a detailed Refrigerator illustration, click below.
Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Hope this may help;
Regards,
VOTIT
    Brigadier General:
  • 3,614 Answers
Check if your fridge still has freon on it..
    Master:
  • 763 Answers
Try to send it to repair service it must be a freon problem. hope that helps!
CHARCOIS
I have a sub zero model 532. it is bulding ice insid the fridge and not cooling well. whenever i open the frizer door the heavy cloud of air coming out
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 09, 2011 | KitchenAid Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
IFridge and Freezer too cold, temperature wont adjust.
you need a new thermostat e z to put on it takes a phillips screw driver the t.stat is hooked right to the knob that you turn to adjust the temp
Feb 24, 2010 | GE Refrigerators
Model 532 freezer will not freeze
Check a Condenser, if it dirty and full of dust and lint - clean it with soft brush vacuum, it's behind the grill with Sub-Zero logo on it. Right hand side usually
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
My sub-zero fridge is about 20 years old. About a week ago, as it got hotter here in New Orleans, the beer bottles were sweating and not cold enough. So I adjusted the knob, and the next day everythin
what a **** way to make money. why can't you people just help people, instead of making it sound like you really wanna help, when all you really want is to make a buck. maybe i'd believe in your little program (sort of like a prob-specific online "Car Talk"), if I had some testimonials. Otherwise, find a better idea, guys.
May 12, 2009 | Sub-Zero 642
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 532
try this link it might be helpful to your freezer
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
dont forget to rate my post at the previous post. thanks!!
CHARCOIS
Sep 03, 2008 | Refrigerators
Sub zero 532 freezer
Confused: you say the temp. won't go UP! Are adjusting it the wrong way possibly? Check your users manual on procedure. Make sure nothing is preventing proper doors closing and not sealing properly,
Dec 24, 2017 | Freezers
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Refrigerators Logo
396 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
