Question about WYSE Winterm 3150SE Network Terminal
Wyse 3150 terminal - yellow light
After shutting down the terminal it refuses to start up. The yellow light comes on and goes off again. Then it works and then it doesn't - have ruled out PMS !
  • Anonymous Oct 01, 2008
    my issue is exactly the same - but with a 9150se - there must be a "quick" fix!
Does it boot into BIOS if you hold down Delete while powering up the terminal?
Posted on Oct 07, 2008
Wyse S30 power settings
You can check the settings in the bios (password will be "Fireport") I dont think there is anything in there that would trigger this.
Is there a screen-saver option in the control panel for the device? If so, see if it is set. If not, then try using the Wyse website to update the terminals OS to the latest. This will hopefully solve the problem. It might just be an incompatability with the older OS version.
Jun 22, 2009 | WYSE Winterm S30 Network Terminal
Wyse terminal does not boot
It should seem to be a hardware side problem.
Jun 04, 2008 | WYSE Winterm 3150SE Network Terminal
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
Wyse PXE boot error
All Boot devices in BIOS may need to be set to "NONE". When shutting down, select "Shutdown and Restart the system, then hold the "Delete" key down while clicking the OK button. Keep holding the "Delete" key until system restarts in setup. Password that I was given is "Fireport". If that gets you access, then set all boot order configuration items to "NONE", then "Save Values and Exit". Hope it works for you as well as it did for me.
Feb 08, 2008 | WYSE S10 (90210501) Network Terminal
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
WYSE Winterm 3150SE Network Terminal Logo
938 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
