Jorge benavides NESECITO EL DRIVER DE LA IMPRESORA HP PSC 1410
voodoomox
  • 1689 Answers
SOURCE: free download driver HP PSC 1410
here is where you get the software for your printer.
HP PSC 1410 Software Download.
just click on the link and then choose your operating system...
hope this helps
-voodoomox
Posted on Sep 19, 2008
pineworks
  • 4041 Answers
SOURCE: error 5B00 de la canon mx300, como lo soluciono?
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
  • 71 Answers
SOURCE: hp office jet 4255 all in one ( error 0xf0af800)
Trata de bajar el nuevo driver directamente de HP e instala tu impresora otra vez. Muchas veces eso resuelve el problema
Posted on Jun 09, 2010
  • 56 Answers
SOURCE: Tengo una impresora de Modelo Hp
It is possible. The message is caused because the printer cannot read the little chip that is on the cartridge. Usually replace the toner will fix the issue (specially if its not hp). In your case it might be the reader that is not working. Try taking the cartridge and paper out. Then reset the printer by turning it off and press and hold the down arrow and cancel. Then turn it on and wait for the message ''permanent storage init'' then release the keys and will get back to ready.
Posted on Sep 07, 2010
My canon imageclass mf4770n keep saying download waiting when i push the start button why
Voy a describir el procedimiento tal y como lo hice y logre revivir mi impresora.
1. Utilic? un equipo en el que jam?s fue instalada la impresora as? no instalar?a el driver autom?ticamente. (No s? si funcionar?a desinstalando el driver de la propia PC)
2. Conectar la impresora al equipo y esperar a que muestre el mensaje USB AVAILABLE. (IMPORTANTE. no instalen el driver de la impresora. Windows la reconocer? mas dar? error al no encontrar un driver compatible)
3. Descargar la utilidad de actualizaci?n de canon Win_MF4800_4700_FirmUpdateTool_V1504_usEN.exe
4. Ejecutar la actualizaci?n de Canon. Esta actualizaci?n deber? detectar el firmware da?ado y proceder? a actualizarlo. En mi caso fue el N?mero 4.
NOTA: es importante disponer de una fuente de respaldo (UPS) ante probabilidad de fallo en el suministro de electricidad ya que ante un fallo como este quedar?a la impresora inservible.
Sep 27, 2014 | Canon imageCLASS MF4770n Black/White Laser...
Video de como limpiar impresora hp psc 1410 con problema de que no imprime
Disculpen tengo una hp 1410 pero no enciende prende por unos segundos cuando la conecto a la corriente electrica y despues ya no enciende por su repuesta muy agradecido
Jan 27, 2012 | HP PSC 1410 All-In-One InkJet Printer
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Necesito instalar la impresora pero la comutadora no reconose el programa
Hola:
Tu puedes bajar el software directamente del internet, solo tienes que ir al sitio de la marca de tu impresora, por ejemplo si es una HP ve a: www.welcome.hp.com. Y haz click en support and drivers y escoje el modelo de la impresora que compraste. Es todo.
Mar 07, 2011 | HP Computers & Internet
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
Tengo la impresora pero se me perdio el disco lo nesecito
Con la Marca y el Modelo de tu impresora puedes ir a la pagina de la compa?ia de tu impresora y bajar el programa (drivers) para configurar tu impresora
Nov 17, 2010 | Computers & Internet
Dell no me reconoce impresora HP
son los otros equipos con Vista?? si no asegurarse de que la impresora es compatible con Vista si no es aquí un enlace para descargar el software de la impresora:
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_product=CB745A&h_lang=en&lang=en&cc=us&h_cc=us&h_page=hpcom&h_client=S-H-R329-1
Printers and faxes > and select add printer..." closure_hashcode_1ku7tc="230">Si el CD no Vista apoyo intente ir a Inicio> Impresoras y faxes> y seleccione Añadir impresora ... esto le puede ayudar en tratar de instalar la impresora. Si no, no sé qué más podía hacer ...
Feb 25, 2010 | Computers & Internet
Free download driver HP PSC 1410
hope this helps
-voodoomox
Sep 19, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1410 All-In-One Ink Jet Printer cd installer
I misplaced the cd installer for my hp psc 1410 all in one and need a quick download.
Oct 15, 2007 | HP PSC 1410 All-In-One InkJet Printer
89 people viewed this question
jasbo
jasbo
