Question about Texas Instruments TI-92 Plus Calculator
Help with a TI-92
I have had this TI-92 for years my brother gave it to me. I am now taking a class and need to use it. So i changed the batteries thinkin that was it but then when i put the batteries in the screen turned black abd stayed black cant get it to do anything else? any ideas?
Try to push the green diamond button once then use the plus or minus keys to change the brightness of the screen.
Posted on Sep 24, 2008
Adjust brightness by pressing the key on the lowest row in the second position and then - or +
Posted on Sep 04, 2008
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
TI 92 Turns on but has a black screen.
This is expected behavior when batteries are replaced and you don't need to reset the device, simply adjust the contrast more than you would think it should take.
See the answer to a similar question at When powered on the LCD screen is dark blue.
Jun 23, 2012 | Texas Instruments TI-92 Plus Calculator
A friend gave me a TI-86 graphing Calc. I wont turn on!!!
maybe try changing the small memory battery inside, I think its a cr1616 or cr1620. If this doesn't work use it as a paperweight.
Apr 23, 2009 | Texas Instruments TI-86 Calculator
Ti 92 will not turn on
Adjust the screen contrast
Press and hold [diamond] button (green near th [ON] button).
Press [+] to increase the contrast and [-] to decrease it.
Hope it helps.
Feb 01, 2009 | Texas Instruments TI-92 Plus Calculator
TI-92: Power loss while not in use.
You may be right. I have left batteries in my TI92 for years without using it. When I put in fresh batteries, it came back to life. The backup battery of my TI92 (bought a dozain years ago) has not been changed yet.
Hope it helps.
Dec 04, 2008 | Texas Instruments TI-92 Plus Calculator
TI- 83 Plus Silver Edition problem
Many TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 29, 2008 | Texas Instruments TI-83 Plus Calculator
TI- 92 crashed
I would not let it lie to rest yet. Play again with the contrast: Lower it so
Press [diamond] key the green one beteen the [ON] and [2nd].
If that does not work it may be because by removing the batteries while the calculator is [ON] you might have pressed inadvertently a button on the keyboard, and that can lead to erasure of the OS. Besides, you cannot change all batteries at the same time:Backup batterie should be in and in good working order when you change main batteries. Similarly, main batteries should be in place when you change backup batteries.
There may yet be a chance to get it back to life and that is to install the operating system through a computer.
You need the cable (TI SilverCable from Staples or Office Depot).
You need to download The TI Connect Software from education.ti.com and install it on the computer.
After installing the software on the computer, run TI connect, then connect the calculator to the computer, and press the [ON] key. Usually it turns on as soon as you plug the TISilvercable into the calculator port.
In the TIConnect window there are several icons (TI device explorer, TI Screen Captrure ) You may try to use them to see if the calculator responds. If it does you calculator is not totally damaged).
Whatever the results of the foregoing actions, you should try to install the OS.
At the top of the TIconnect windows there are 4 round buttons (2 green, 2 gray). Click the Update button. (you must be connected to the Internet) If it works, I congratulate you. If it does not, I have no idea what you might do next.
Hope it helps.
Jul 23, 2008 | Texas Instruments TI-84 Plus Silver...
TI-92 Plus don't turn on
Your calculator's software is probably corrupt. I suggest you buy a new calculator
Apr 24, 2008 | Texas Instruments TI-89 Calculator
TI-89 Won't Turn On
Please don't get your hopes up, but perhaps something in the following few suggestions will work:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  1. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  2. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  3. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
To reinstall the Calculator's operating system, take a look at the following TI site.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetNumber=12089
I would hunt around on the TI knowledge base to see if there are some more useful suggestions if nothing above works. If I find any more info that could be useful I will post it.
Mar 06, 2008 | Texas Instruments TI-89 Calculator
Ti-89 wont turn off
I'm having the same problem:(
I need to solve this urgently, i can't stand always being removing the batteries... please help me!!!
Oct 16, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-92 Plus Calculator Logo
648 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
