Question about Bosch WFMC 3200 Front Load Washer
Replacing boot on Bosch Nexxt Front loader
We are trying to replace the rubber boot on our Bosch. The problem we have is in trying to get the spring loaded wire around the boot. Any suggestions?
Are you talking about the thin wire closet to you... if you are, you'll find a small bend in the wire where you can pull it out. It is right next to a spring on the wire.
Posted on Sep 07, 2008
  • tonyoregon1 Sep 07, 2008
    If you are talking the spring looking retainer thing...closet to the tub... you'll need to carefully (like with a flathead) get under the spring and pull up slightly. it pops right out. Once you get it out, you'll notice it connect to itself s on one side... but you really can't see that till you get it out. Which ever spring, retainer you are talking about they are both easy to remove. I just did both. Now I need to get a replacement boot.
    the one closest to you is called the fastening ring. The one closet to the tub is also called the fastening ring but it is not a wire but a long spring. Looks very different.
Is there a replacement part for the rubber gasket for door of washer? I can't stand the mold.
you can get parts from ebay
This video will show you how to change a door seal on this Bosch front loader washing machine
Jan 03, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wire that holds the rubber gasket came off
can usually take to people if you are not familiar.the spring does down towrds the bottom of the boot in the middle of the boot start with the ring at the top and go down both sides the have someone hold it in place about the 10 and 2 o clock positions while you use your hands or small screw driver and finish putting the ring in place
Jun 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFMC 3200 Front Load Washer Logo
249 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
