Question about Refrigerators
Frezer is working, but refrigerator is hot and not cooling. fan and motor are both working. model ctx18 hotpoint
  • 535 Answers
Check the compressor of your refrigerator
Posted on Sep 03, 2008
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Hi my botton frezer no working the compressor its hot
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Oct 05, 2010 | Amana ARB8057CSL Bottom Freezer...
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at
Dec 30, 2009 | Refrigerators
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
We have a hotpoint refrigerator. The Frezer seems
There is a part called a defrost timer, it is usually the most likely culprit in these situations. Hope this helps
Oct 07, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint refrigerator ctx18; blower is on but when
you are goung to probebly need te install a three-in-1 relay on the compressor to assist in getting the unit to stay running and npot brealk down.
Mar 21, 2009 | GE Refrigerators
I have kenmore side by side it seem very warm between frige and frezer by door handle never felt warm before (26foot elite) about 4 years old
i pulled the frige out to clean around the coils only to find the cooling fan was not hooked back up buy the last repair man that changed a thermostat a month ago be for i put my tool away it was ok
Feb 20, 2009 | Hotpoint HSM25GFRSA
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
