Question about GE Advantium 120 Convection/Microwave Oven
How do I replace the door handle on microwave?
  • duchenelawre Oct 03, 2008
    I got the part shown on You Tube off but the handle has TWO screws top and TWO bottom. I have removed one top,one bottom the other two are behind the unit holding the window. How do I remove the window unit? Larry
    GE Microwave model JVM1440BD001
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
    Normally
    you have to separate the door panels (as shown in the attached photo)
    and then you'll see the previously hidden screws you need to remove.
    Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Once you follow the youtube instructions to remove the inside cover you are ready for the next step.
Remove the six small screws that are adjacent to the window. After this the front plastic is held in only by plastic clips to the metal door. The plastic clips and the screws together hold this together.
Remove the entire door by lifting up and move it to a flat service. If the top vent cover prevents this just remove the two screws on top of the microwave and pull the vent cover off.
With the door lying flat you can pull the plastic frame out on top and bottom and see how the clips work. Now just work you way around the frame until it separates.
Install handle and reassemble in reverse order.
Posted on Nov 20, 2008
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
How-To Replace The Door Handle On A Kitchenaid Microwave Hood
behind door their is trim round the door use flat knife go between the trim will pop out and open 2 sc
Feb 01, 2015 | KitchenAid KHMS2050SSS Microwave Oven
How to replace handle
This is a difficult thing to explain in the text forum to change. Go to Youtube or RepairClinic to see videos to make this easier for you. Whirlpool microwave door handle replacement Door Handle Replacement part WB15X10249 GE Microwave Repair
I hope this helps
Aug 01, 2014 | Frigidaire FFMV162LW Microwave Oven
Replacing a handle on a kitchenaide microwave
Hello
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Microwave Ovens
Replace handle on whirpool microwave
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
If you have not purchased a new handle yet, the part number is 4359474 (Black) and 4359473 (White) and costs about $30.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool MH7135XE Microwave Oven
Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door handle
First, never remove the door. You will disturb the alignment which holds in the microwaves. Generally, the door can be disassembled by removing the screws on the cavity side of the door. Once inside, then you should be able to replace the handle. Often the screws are of the torx variety...also call star.
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
202 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
