Question about Panasonic KX-T7630 Corded Phone
I Need Help
I have a Panasonic kx-t7630 system. I can make phone calls out, but i can't recieve. Usually when i recieve a phone call the answering machine turns on, and tells you where to transfer the call. the answering machine is not working!!!! i see phone calls coming but i can't answer them. how can i deactivate the answering machine ? please is urgent.
  • nouriely Sep 03, 2008
    Where can i find settings and advance settings?
    Genius:
  • 1,239 Answers
Hi sir
go to the settings>
advanced settings>
answer machine > enable.
it work's thank u. sir
Posted on Sep 03, 2008
SOURCE:
How much Panasonic Hybrid system KX- T7630 cost
..unfortunatelly KX-T7630 is just digital terminal compatible with several models of PBX-s.. it is not possible to answer your question
Mirro
Jan 22, 2015 | Panasonic KX-T7630 Corded Phone
How do I connect a background music source to Panasonic KX-T7630 phones?
The Music On Hold (MOH) is not connected on the KX-T7630 Phone but rather to the phone system. You will need to get an extension from the phone system and connect it to the KX-TVM50/200 Voice Processing System (VPS). Incoming calls are then answered by the extension connected to the VPS ... i sugest you get a Tech to help you with setup or get an online programmer to guide you on hardware setup and he does the programming for you.
May 27, 2014 | Panasonic KX-T7630 Corded Phone
Our Panasonic KX-T7630 phone system does not have voice mail built in. What sort of answer machine should I purchase to use with it?
Any digital answering machine will work just fine for you. These days you won't be able to find any of them made with tapes. You could also check with your phone company provider about voicemail service.
Apr 21, 2011 | Panasonic KX-T7630 Corded Phone
I would like to set up an answering machine on Panasonic kx-t7630 but don`t know how.
A 7630 is a digital phone that connects to a TDA/TDE or NCP Panasonic phone system. There are 4 analog ports in a TDA-50 or lower phone system, so you could install an answering machine on the first 4 ports of a TDA by default. If you have a TDx-100 or higher, you have to have cards that contain analog ports.
However, you could always wire the answering machine on a specific line.
Carl
Jan 15, 2011 | Panasonic KX-T7630 Corded Phone
How do I conference call 3 parties using Panasonic KX-T7630 Phone?
1:Call First party/ When answered press CONF button top left hand corner
2: Call second Party/
3:Press CONF button once again.... Thats it
Sep 24, 2010 | Panasonic KX-T7630 Corded Phone
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
Mailbox recieves messages but is not saving them (KX-T7630)
This sometimes happens on my phone. The only way I have found to clear this is to leave a voice-mail. Check your messages delete the test message and your system should clear itself out.
I think what happens is it gets stuck thinking there is a message. So when you clear the new message it then realizes there is no more messages. I know this works on my phone and could be the same for yours.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 20, 2010 | Panasonic KX-T7630 Corded Phone
Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Apr 23, 2010 | Panasonic KX-T7630 Corded Phone
Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
Jun 19, 2009 | Panasonic KX-T7630 Corded Phone
Stuck on Night Mode
Your phone can work on different Panasonic phone systems that program differently. I would need to know the model number of your phone system to look up specific information.
Until I get that info from you. Most systems can only be turned on and off from night mode at one phone station (usually the operator) but others will let you program a programmable key on any phone to do this. It's also possible to enter a function code from any phone on some systems.
Does it say Night Mode on a display? How do you know it is in night mode? If it is on a display, is it on all the displays or just one? If just one then that is the phone that can turn it off.
Nov 19, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
286 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
