Harman kardon avr 245
Harman kardon 245 want to hook up to a tv, lcd it has hdmi and s video want to listen to tv channels dont have sky tv so its only 4 channels bbc1 bbc2 itv and channel 4.The lcd tv the sound is bad form tv, bought the avr to listen to the tv. also the e-setup osd how do i get that to come up on the tv what leads do I need etc.chhers
  • 10 more comments
  • purplecatque Sep 03, 2008
    Have the red and white rca leads in the tv, where the tv manual states put them, but still no sound.??
    cheers
    I can listen to dvds with surround sound no problems , sounds fab with the Haman kardon 5.1 speakers, have a mini disc player, harman kardon dvd player, just want to listen via tv channels?? leads have bought hdmi, optical, and svideo.
    245
    its the 245 model
    it says on the manual AVR Harman Kardon AVR 245 Audio/Video Receiver
    We have a sat receiver, but that needs attention the LNB has stopped working another job to get soreted, but will be mended soon. Just got got analogue tv at moment. We have bought HDNI lead, s-video lead and optical leads, im a woman so bit of a novice, hubby is quite tec minded but we are stuck now, loads of leads but dont know where they all go???Hence a big jumble.Thanks for your help so far, yes the tv remote has av extentions up to ex 5 and pc.
    have sorted one problem out the e-setup now works on screen so have on screen display on tv, hubby had the s-video in the wrong socket, he read the manual over and over. so just need the surround sound to work via tv, so dont have to listen to the **** sound on lcd drives me nuts to boomy.
    Still need help with this avr, feel like burning manual waste of time so much jargan please help someone all I want to do is listen to my tv with this avr with surround sound...
    xx
  • purplecatque Sep 04, 2008
    Harman kardon 245 want to hook up to a tv, lcd it has hdmi and s video want to listen to tv channels dont have sky tv so its only 4 channels bbc1 bbc2 itv and channel 4.The lcd tv the sound is bad from tv, bought the avr to listen to the tv. what leads do I need etc.cheers am running the av along side the HKTS-11 Harman kardon 5.1 speaker system.
    Any help please
    thank you very very much for your help so far, will get hu
    bby to start all over again big thank you.keep you posted.
    kind regards
    shelley
    Thanks for your assistance the model of the tv is Evesham Alqemi sx , ceased trading.
    Master:
  • 788 Answers
It would help to know what model TV you have. You will have to connect an audio output on the TV to an audio input on the receiver as your TV is doing the tuning since you are on analogue.
If you are using RCA (Red and White) cables from an output on the TV you would connect it to either VID1 IN, VID2 IN, or VID3 IN.
Posted on Sep 04, 2008
  • Dean Joly
    Dean Joly Sep 04, 2008
    Check out this link: http://www.avforums.com/forums/showthrea...
    I wasn't able to find a manual yet for your TV but it would seem that you need to set the volume for each output and that the default is 0. Go throught the menu on your TV and fidn the spot where you can set the volume of the audio outputs. Set that volume to somewhere between 50-100%. You may need to adjust it so that it plays nice with your receiver.
  • 185 Answers
Adjust the receiver in proper position and fix it,it may helps u.
Posted on Sep 03, 2008
  • 4,472 Answers
Do you have a cable box going to the tv? What are you watching on the tv? Once I have all the information I can properly assist you please don't reject my help until then.
Thanks,
Lee
  • 1 more comment
  • Lee A.
    Lee A. Sep 03, 2008
    What you will want to do to hear the audio your tv would hear. Is take the audio out of your sattelite box to one of the inputs on your stereo reciever. If you need any more elaboration let me know. I will be happy to assist you further as I know we can get this issue worked out. What is the model of the sat. reciever and the model of your tv.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 03, 2008
    What is the model of your tv? You will need to go from the audio out on your satellite receiver to the input on your surround sound receiver. Unless your tv has an audio out. Then you will go from the audio out on the tv to one of the audio in's on the surround sound.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 03, 2008
    All you need to do is go from the audio out on your sat reciever to an audio in on your harmon kardon. I hope that you will accept my help as soon as it is available as an option, I am sure I can work you through it.
    Thanks,
    Lee
    Brigadier General:
  • 3,614 Answers
What is the receiver model?
  • 19,396 Answers
See what connectors you have on TV, easiest way to connect is using RCA or composite. About the sound, connect a surround system to the receiver.
  • 2 more comments
  • Ginko
    Ginko Sep 03, 2008
    If your tv has composite use the following cable:
    Belkin 12' PureAV Composite Video Cable
    If not use RCA cables:
    Cables To Go 6-Foot Value Series...
    Steren RCA Audio Y-cable
    Yellow is video, rest are audio.
    For the audio problem, buy external tv speakers at a local dealer.
  • Ginko
    Ginko Sep 03, 2008
    TV must also have a source selector command, see the remote and switch source input to AV.
  • Ginko
    Ginko Sep 03, 2008
    If you have HDMI on TV connect through HDMI, and that is all use only connection type if you connect all cable to TV the situation with settings risk to get quite confused.
    After connecting select right input on TV.
  • Ginko
    Ginko Sep 03, 2008
    Here is the Harman Kardon backpanel:
    Connect aerial to antenna,
    Connect audio to the audio out connectors at the left in picture, using RCA cables : RCA Audio Y-cable
    Connect TV to aone of tv inpiuts of your choice. The yellow one is RCA, otherwise use component video cable or HDMI.
    Select input on tv to the correspondent input connected on the receiver.
    If you want to use also the tv as standalone connect the coaxial out to TV aerial.
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
Can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Hook-up
http://wzpo.ask.com/r?t=p&d=cap&s=fwpus&c=a&l=zr&o=sb&sv=0a300516&ip=29b28a2c&id=9C081BFE154A69ACB38D55982924AB2E&q=manual+of+harman+kardon+avr+120&p=1&qs=121&ac=29&g=33c8zcdlUuHiRw&en=te&io=0&ep=&eo=&b=alg&bc=&br=&tp=d&ec=10&pt=Harman%20Kardon%20AVR%20120%20Receiver%20Owner's%20Manual&ex=tsrc%3Dtxtx&url=&u=http://www.manualnguide.com/download/manual-guide/harman-kardon-avr-120-receiver-owners-manual.html. have a look in manual above from page 9.
Sep 06, 2008 | Harman Kardon AVR 120 Receiver
257 people viewed this question
 Grubhead
Grubhead
