Question about Panasonic Televison & Video
I have a Panasonic TX-23LXD50 LCD Digital TV and recently when turning the TV on, a message appears "New DVB Services Found. Press OK to add new service. Press EXIT to ignore". When I press OK, it searches for a new channel but then come up with "No services found". The TV works as it should but this is just a nuisance. Thanks.
2 Suggested Answers
SOURCE: Thomson DTI550 set top box problem
I'm beginning to think that there will not be a download for the DTI 550. I've just searched the Thomson website and they say that they no longer offer support for these products in Europe.
It looks like it's destiny is the bin.
Posted on Nov 07, 2008
  • 309 Answers
SOURCE: Message on screen says please
The message indicates that the TV is not receiving a signal from either the external tv antenna or from the cable company. So, if you have cable, and it is correctly connected to your TV, you need to call the cable company for service. Once you have a signal, THEN you can run auto setup to capture the channels to your set's memory.
Posted on Jan 07, 2010
I have a Panasonic TX-48CX400B and can't find the pip button how do I get split screen off tv.
The PIP mode is only used to show the current source if you are also looking at the Internet portal mode. After you set up your network connection, press the Internet button on the remote to access the network options. (That's the button with the globe and an arrow that curves up from the bottom right of the globe.) Press OK to select an internet option.
See page 28 of the manual for more information. (I found the manual for the TX-48CX400E here, http://www.panasonic.com/uk/support.html , and looking through the list of LCD TV models. Then click on the Downloads link and then choose the version of the manual you want. From here, you need to accept the Panasonic terms of use for their downloads. The direct link to the manual is http://tda.panasonic-europe-service.com/docs/2z56564c5ez3z3bebbz656ez706466z23zba9e6b6cadec0298b6a49aa5ad340d60c1bb0f19/pgrp001/pcat033/tx48cx400e/933026/BG1WLCAKK3RR.pdf . This is the same model sold in another country.)
I hope this helps.
Nov 25, 2015 | Panasonic Televison & Video
I have a nw MAT19W127 tv and cannot receive BBC!, BBC2 and BBC3 on the freeview service (BBC4 is OK) Message shown is "No Signal". I have tried reloading the channels but still nothing. Othe...
dear,
in tv a device used called Hyperband, means
Hyperband
In the service channel network, the frequency used for distributing TV stations (300 - 470 MHz). It is the range of choice for digital transmissions according to DVB-C.
sometimes, it happens that the hyperband installed in tv doesnt catch/recieve the frequency of the channels. i think your case is like this..
you have to change it .. its not very costly..
there was a problem in my LG tv that i was not recieving the Discovery channel freq. then i had to replace this part. now i can see it..
regards,,
Aug 07, 2008 | Televison & Video
The "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Jan 05, 2011 | Mitsubishi WD65737 65" DLP TV
Need to reset the lamp timer
1 turn tv on
2 press vol- on tv and pip on remote at the same time for more than 5 sec a message will appear
May 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Message on screen says please check aerial or local dvb service availability, press OK to start auto set-up - but this doesn't help
Jan 07, 2010 | Panasonic Televison & Video
I have an Orion TV32rn10d and i have error reporting cannot access digital services although it was working fine this morning
I had this problem as well.... the TV jsut froze and then it turned onto analogue and when i press the TV/DVB-T button it came up with the following message...
Error
Cannot Access Digital Services
Solution...
I pulled the plug out the back of the TV waited 5 seconds and put it back in...
suprise suprise it works :D
Sep 08, 2008 | Televison & Video
Why do I always have the message:" A new DVB service has been found" when I switch my television on, and yet there are no new updates?
its not your TV its your free view box telling you its found more channels. DVB means 'digital video broadcast.' go into menu and select search or update channel list
Jul 22, 2008 | Panasonic Televison & Video
Set up new panasonic th-37px80b tv last night. Its connected to a v box via scart and hdmi and dvd player via scart. It is not connected to an aerial so only watch tv via the cable box. The problem is I...
The set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT. Solution found on Fixya by QTV1 posted on Nov 20, 2007
Mar 08, 2008 | Panasonic Televison & Video
Televison & Video Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
