Question about Kenmore 16872 Built-in Dishwasher
Electicity going to dishwasher but when program dial turned it doesnt start program even though its switched on and door closed
Small amount of water at bottom of dishwasher, electricity is going to the unit no breakers are blown, no light nothing responding on dishwasher
Posted on Nov 24, 2008
Kenmore dishwasher will not start
The most probable cause is the door latch (or switches in the latch) are not working right, and the controller thinks the door is open, even though it is closed.
Aug 13, 2012 | Kenmore Dishwashers
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
Whirlpool dryer push start button and nothing happens
check the switch that detects that the door is closed,it can break even though the door is closed it doesnt start
Sep 21, 2009 | Whirlpool Dryers
Does not start. Cannot change programs
What is the manufacturer and model number of your dishwasher?
Approximately how many years old is it?
Are you saying the water never enters the dishwasher, even on the one program that you have?
Apr 11, 2009 | Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE Nautilus wont start
check the two switches under the inside cover of the door. there are two switches under the flimsy metal switch actuator, one switch has a black wire in both ends the other switch should have two white or white/red strip wires on one end and one white or white/red wire on the other end. the black wire is power the white wire is your neutral. both switches should have a button in the middle that is pushed in by the flimsy metal switch actuator when you lock the door shut. i had to replace the switch for my neutral when mine quit working. you can remove this switch and get the part number off of it. you can look it up on line or call a small appliance repair store to see if they have the part or can order it for you. remember to unplug the dishwasher before you remove the the inside cover of the door. hope this helps. Sparky TJ
Aug 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Diswasher won't run
first check the circuit breaker box you might hva tripped abreaker, next close the door softly, and listen to perhaps hear the door switch activating, id the door doesnt close (bad switch) no power to rest of d/w
Feb 23, 2008 | Kenmore 15522 Built-in Dishwasher
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Kenmore 16872 Built-in Dishwasher Logo
146 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
