check this out
loosen the the
two bolts (show on the figure above) first
loosen also the bolt used for
adjusting tension.
remove the old worn-out belt.
place the new belt (you may need to loosen further the tension
adjusting bolt)
when belt is properly place, tighten it enough the tension adjusting bolt,
(not too tight, but not too loose) press the belt to ensure its not too loose!
When belt tightness is enough, tighten the the other lower one of the two bolt then the lastly tighten the pivot bolt.
gookluck!!!!
