I have an HP 2210 - this AM I replaced the black cartridge (#56) - afterwards, the align cartridges procedure keeps cancelling in mid-job
I have cleaned both cartridges twice and I still cannot get the cartridges to align
The problem with HP printers is always either in the cartridges or in the mechanism that manages the pages inside. It is very rare to find a different problem. So in the first case you should try to buy another pair of cartridges, ORIGINALS just in case. If that is not your problem it wont be importar, you will just have more ink for the future... If with that the printer is still giving problems, then it surely is the mechanism and unless you know how to disassemble it you better take it to an HP service center with both original cartridges so they wont tell you the problem are the cartridges. Best luck!
This morning I printed something on the printer without any problems.This evening when I tried to...
(More)
This morning I printed something on the printer without any problems.This evening when I tried to use it, I saw that it was not on, though it was plugged into a powerstrip that was on and successfully powering my computer. The printer did not respond when I pushed the on button. I tried unplugging it and plugging it back in, but without success. I checked the cord and the cord connection in the rear of the printer.Any suggestions?
I get a remove and check cartridge error message. Have removed and installed new but still get...
(More)
I get a remove and check cartridge error message. Have removed and installed new but still get message
How do I fix "Remove and check cartridge"? I removed both cartridges, shook them and put...
(More)
How do I fix "Remove and check cartridge"? I removed both cartridges, shook them and put them back in but the problem display is still on.
