Question about Welbilt DF4050 Deep Fryer
Welbilt DF 4050
Does the pot you put the oil and the basket in come out for cleaning
  • 13,433 Answers
That should be covered in the user manual, there is very little information available on this product, not even a user manual so its hard to confirm this.
Details:
Non-stick pot. Adjustable Thermostat. Interlocking folding handle. Permanent mesh filter. Convenient pour spout. Removable lid. Easy-view window.
at this time Im unable to give you a solid answer. Remove the lid and try gently. If you have the copy of the user manual, which I was unable to get my hands on, check it out.
Sorry for not having a solid answer.
Posted on Sep 03, 2008
  • Ekse Sep 03, 2008
    But Id say, its not removeable. you can confirm this by checking the manual, trying does it move, or even calling the company support directly.
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
My impeller continues to clog with debris that sneaks through the filter basket. Is there anything I can do to prevent the debris from getting into the impeller in the first place? I know there is fi
Try these things, but you need to be diligent in keeping up with cleaning, because the following fixes will work harder & better, therefore you will have more debris caught, that will need cleaning:
Put a "Leggs" style nylon stocking over the basket at the skimmer.
Also, put one at the basket in the Hair & Lint Pot at the pump.
Or you can put a plastic "Chore Boy" pot & pan scrubber in both the baskets.
These fixes, do work.
Good Luck
Aug 25, 2012 | Hayward Pool & Spa
Cant get the cleaning cycle to end dont know how to get it off
If the red light is still blinking, then the cleaning cycle has not yet been completed. The cleaning cycle is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 07, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
Sep 22, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
How do I stop the oily residue in my brewd cup of coffee? The coffee maker is new. The residue is not from our filtered water.
Thoroughly wash the pot and the basket with a good oil/grease remover (detergent) such as DAWN dishwashing liquid.
Then run White Vineger/Water (50/50) mix through the coffee maker TWICE, with the basket and pot in place. (NO coffee, nothing in the basket)
DO NOT RUN any detergent or soap through the coffeemaker at any time.
Then, run straight water through the coffee maker TWICE (no coffee, basket empty)
Then wash the pot and basket out AGAIN with a good detergent.
This will remove any residue that is in the coffeeemaker from the factory.
As coffee brews, there IS a slight amount of oil that is produced. The coffee itself has oils in it, and is part of its flavor, and freshly brewed coffee will have a slight oil residue.
Jun 24, 2011 | Rival Coffee Makers & Espresso Machines
Im cooking fish, how much oil ?
Enough to submerge the fish in the basket. Easiest way to get it pretty close:
1. Place the basket in the cooking pot.
2. Fill to the estimated displacement with water. The estimated volume would about half the height of the basket in the pot, if you were to fill the basket with fish half way. This way you know that you'll have enough to cover the fish when you start frying.
3. Measure the water. If you have the markings stamped in the side of the pot, this is pretty easy. Otherwise, pour the water into a gallon jug, keeping tally on how much water you removed from the pot. A partial gallon at the end is easily estimated. Works the same for liters, depending on where you live.
4. Dry the pot thoroughly before you add the oil.
Best regards, --W/D--
Jan 28, 2011 | Eastman Outdoors 38065 Turkey Fryer
I need a new basket for the welbilt deep fryer 4050
Welcome to fixya
I have a solution for this
Content
Best way to locate these parts is to check the manufacturers website for spare parts.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Welbilt DF4050 Deep Fryer
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
Cuisinart coffee maker from costco, the grinds backed up twice.
It sounds like the release at the bottom of the basket was not open when you put the pot in to receive the coffee. You might check the release on the basket by takin the basket out, putting water in the basket and tripping (pushing up) on the botton on the bottom to see if the water flows through. It could be clogged.
You should clean the coffee maker about every 30 pots of coffee to keep scale from gathering in the heating tubes.
May 19, 2009 | Cuisinart DCC-1200 Coffee Maker
Welbilt DF4050 Deep Fryer Logo
218 people viewed this question
Top Welbilt Kitchen Appliances - Others Experts
Lyle Siemens
Lyle Siemens
Colin Stickland
Colin Stickland
Are you a Welbilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
