Question about Lexmark Office Equipment & Supplies
Unable to print in color using lexmark x4270 - Lexmark Office Equipment & Supplies
  • 11 Answers
SOURCE: no color printing with lexmark x4270
Actually your printhead on the cartridges is probably clogged. I usually take the cartridges out, wet a paper towel and put in a dish and put in microwave for 20 seconds, then put the cartridge printhead on the paper towel for 10 seconds, and then blot with a dry towel. You should see the various colors in the color and black cartridges. Do it several times until ink in freely flowing. Put back in printer and run a clean cycle and try printing normaly. For additional help: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS18888&relevance=1
Posted on Mar 07, 2007
SOURCE: Lexmark X4270 won't install
lost my lexmark c.d to install what should i do
Posted on Dec 24, 2007
  • 390 Answers
Have you told your pc the fax equipment you want to use, and does it appear in the device managers list?
Posted on Feb 12, 2008
  • 390 Answers
SOURCE: blurry printing fro lexmark x4270
May be too much info blocking up print memory. Before printing off sites, make sure you clear print queue and slect printer friendly versions. Check to see if your printer has a work online or offline setting in preferences too.
Posted on Feb 14, 2008
IB4G2008
  • 3587 Answers
SOURCE: lexmark X4270 doesn't want to scan
sounds like your scan settings need a look..do you have the print manager installed?
Posted on May 03, 2008
Color ink cartridge
Well due to some problem in cartridge you would be facing this problem.however you can do try this.
Please clean your cartridge once again with some spirit.
Fix it well in the printer afterward.
Than use normal paper and print in color.
If than also it does not work that means the bar-code of the cartridge has problem in it so the printer is unable to read that code, so for that you need to change the whole cartridge.
Or if your printer had valid in warranty period and it still in that period just give it to a service center.
If you still had any confusion regarding the same problem or nay other please do reply.
Naiven.
May 31, 2010 | Lexmark X4270 All-In-One InkJet Printer
Unable to get my Lexmark 4200 off the default setting of color, want to print in Black/White and select color if I want to print in color .
Good day! Here's an article in the Lexmark website that will show you how to use the Print Properties Dialog on the Lexmark 4200 series. It has some graphics to better understand the instructions. Just click on this link: http://bit.ly/bvMxnp . You should be able to come across Print Color images in Black and White option. Hope this helps. Good luck!
Mar 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
How do I get my color ink to print on Lexmark x4270 series
Most drivers default to color. In Windows, go to your printer folder, right click the driver and click on Properties. Check the settings to see if color is selected as default.
If it is color, your application is overriding the driver color settings and would have to be changed in that before printing.
Sep 10, 2009 | Lexmark X4270 All-in-One Multifunction...
Print A3 to 4xA4 pages on Lexmark X4270 All In One
Hi!
Please download this software for converting your dwg, dxg,etc files into jpeg---
Dwg to jpeg Converter
And, regarding printing in black color only, you need to give it a print command and the click on prefrences button and from there select print in grayscale and then you will be able to print.
Please ask for any further clarifications.
Please rate this solution as Fixya if found helpful.
Thanks
Rylee
Feb 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
I HAVE INSTALLED THE LEXMARK 4200 SERIES PROGRAM ON MY COMPUTER THE LEXMARK IS A X4270 MODEL. BUT I AM UNABLE TO PRINT MATERIAL FROM THE COMPUTER TO THE ALL IN ONE LEXMARK OFFLINE OR ONLINE. IS THERE...
START- CONTROL PANEL-PRINTER AND FAXS.
Is it listed there? If not click on ADD A PRINTER, follow the prompts. if that doesn't work , let me know, and we'll try other things. .
Dec 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Color Printing
from the lexmark toolbar check to make sure color is selected not black and white
Oct 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark X4270 and it just stopped printing color after we changed Copy to Black print Black OK Can not get it to Print in color again Thanks
  1. Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  2. Click the Troubleshooting tab on the left side of the screen.
See if there is anything in there about it.
Apr 19, 2008 | Office Equipment & Supplies
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
