Question about Welbilt DF4050 Deep Fryer
Cooking pot doe cooking pot come out to be cleaned
    Genius:
  • 1,665 Answers
Posted on Sep 03, 2008
  • 13,433 Answers
How can I help you, what do you need?
Thanks,
Ekse
What does e01 mean on ninja 3 in one cooking system
EO1" occurs when the unit is still on but the pot has been removed from the cooking housing system. Place the pot back in the cooking unit.
This can also occur for the following reasons:
-if there is food jammed in the gap between the disc and the surrounding heating plate (the blade circle).
-if there is food stuck to the bottom of the pot.
-if there is food stuck on the heating plate (yes even a grain of rice can be a problem!)
-there is mechanical damage to the unit (disc is defective for instance).
-if the handles on the pot got bent down (so the pot is not fully seated on the heating plate and disc does not get pressed)
-debris or other damage preventing the pot from make full contact with the heating plate.
A good tip is to plug in the unit and turned to any mode. Please be sure the unit is completely dry. Use your finger to fully press on the disc and see if EO1 goes way. If pressing down does not clear EO1, then unit is defective.
If EO1 does clear by finger but does not clear when pot is installed - and bottom of pot, heating element and gap between the disk and heating plate are clear, then the unit is defective.
Dec 29, 2016 | Washing Machines
How to fix on a ninja crockpot e01
According to the manual it means the cooking pot is not inserted into the device.
Mar 19, 2013 | NINJA SEARious Slow Cooker
Vegetables take hours to cook. Something wrong??
what do you have your setting on the crock pot for maybe you need a higher setting for them.
Mar 11, 2013 | Rival 38501 Smart Pot 5-Quart
How much does the 5QT Slow Cook Crock Pot 5 Quart cost?
The 5QT Slow Cook Crock Pot 5 Quart generally cost around $40.
Feb 07, 2013 | Rival 5QT Slow Cook Crock Pot 5 Quart
Hi i have a hamilton beach crock pot that only has low, med, and high to cook with. i cannot find my book that has the times or what to put the crock pot on for port tenderlon and how many hours to cook...
Most recipes will have different times to cook meat, I would make good use of www.google.com and look at recipes and suggestions there. Generally speaking I would say you're going to cook that on low for about 4 hours, but it really does depend on the amount of meat you're cooking and your personal preference.
Dec 08, 2010 | Hamilton Beach Crock Pots & Slow Cookers
Defective part
To better address the problem with your nonstick pot... I need more information on the steps you have used to clean the pot and the extent of damage to the pot itself.
You indicated that the damage has occured between the pot and the inner surface of the cooker base? Is this a corrosive damage or a build up of material on the inner liner of the base?
Often times a build up of 'hard water' minerals accumulates on the inner surface due to condensation and occasional overflows from the foods being cooked. They can appear to be a type of fungus or mold.
Jan 04, 2009 | Crock Pots & Slow Cookers
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
Why does my crock pot cook at too high a heat?
With something that small, there is not a lot of resources for parts and repair. The item is considered a throw away. You could contact customer service at RIVAL and see what they say about the issue. Could be mis-wired or something like that. The only easily replaced part for that is the stoneware.
Jun 16, 2017 | Rival Crock Pots & Slow Cookers
Welbilt DF4050 Deep Fryer Logo
97 people viewed this question
Top Welbilt Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Lyle Siemens
Lyle Siemens
Are you a Welbilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
