Question about Funai Televison & Video
Iv inserted a blank disc into the DVD recorder but it is coming up with a message "recording error" "can not record on this disc" "E4 54037380"
  • 56 Answers
Check out the layer format which is suitable for your recorder. DVD+R or DVD-R..
Posted on Sep 03, 2008
  • 535 Answers
If u have dvd +r then u need +r dvd if u user -r dvd its will not work if u have -r dvd then u shoud write dvd -r if u write on +r then it wont work
u have record on if u have dvd +r then u have to record +r dvd if u have -r dvd then record on -r then it will work
i hope it will help u
My toshiba dr4su will no longer record on dvd-rw discs nor will it format a blank or prerecorded dvd-rw.Ihave used this recorder successfully for a couple of years. It will play back dvd-rw. When I attempt...
If its an older recorder it could be the usual problem of a greasy center-disc =
95% OF THE TIMES I could fix a problem like this was by cleaning with rubbing alcohol the rubber ring on the little rotating disc in the center of the drive mechanism. !!!! Because users always stick their index finger into the hole of all the CD'S for inserting a disc into the tray that a tiny amount of grease gets deposited onto the little rotation disc which touches the center of any inserted disc at about half an inch from its center hole. (underneath) When its greasy the discs slide and the inserted discs speed stays uneven and slow.
You must open the drivebox ( after unplugging the power-cable) to see and clean it.
Be careful to not look at it with power "on" because the laser will make you go blind (danger!!!!!!!
I heavily use a Toshiba DVD recorder since 12 years and it is my most reliable and most versatile recorder, while my brand new Sony recorder lasted only 2 years - Others as well had problems with finalizing etc. but in general the cleaning of the little center-disc that pushes from underneath against an inserted DVD to make it spin helps the most.
Oct 26, 2011 | Toshiba DR4 DVD Recorder
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
I recently purchased a pack of staples brand DVD RW's instead of the name brand ones I usually use. When I insert them into the player I get an error message stating that it cannot record on this disc ( E...
Please check if your blank DVD's are dual layer ( DL ) 8.5 GB disc. If so your player does not support dual layer writing. It will record only on 4.7GB single layer blank discs.
Apr 22, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Recordable DVD
can only record 2x,4x, and 8x..........not anything beyond 8x it 1x-16x will not work. Now if I could just get the loading messageto stop on mine.
Feb 06, 2008 | JVC DRM10 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Televison & Video Logo
246 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
