Question about Canon CLC 1000 Color Copier
Error code E350-0000 on canon clc 1000
Is there any particular part than i have to replace and correctly instal to definytly get this problem of E350-0000 solve on canon clc 1000 ???
  • Canon Expert
  • 1,326 Answers
Sorry it took long to get back... I had a problem with my computer. You may have fixed it already. Have you installed a adf on this copier? If so I read in the book that you may have to replace the Left retainer plate with a new one or that it may be damaged. Here is the part number for a new style plate FF5-4662-020... Try to do a full CCD adjust with the new plate.. Good Luck
Posted on Sep 10, 2008
I keep getting error message E004-0002 ( Switch off and on again) everythime I switch on my canon clc 1000
E004 is a temperature related error. You would need to call in a service technician as it will require replacement parts.
Sep 12, 2011 | Canon CLC 1000 Color Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Apr 02, 2010 | Canon CLC 1000 Color Copier
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
the connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Sep 03, 2008 | Canon CLC 1000 Color Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
CANON CLC1000
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Canon CLC 1000 Color Copier Logo
146 people viewed this question
old marine
old marine
