Question about Fujitsu Pocket Loox 600
Use Pocket PC modem connection
Hi. I have got a Fujitsu Siemens Loox 600 whic h I have a external modem for sending files from the Loox to my works server. I`ve got a cable to connect the Loox>Modem. Now I want to connect to the internet using the Loox, and then use this connection to surf the net with my desktop PC running WinXP. Can I do this? I`m very "newbie" with pocket PC`s, so a slow eplanation would be good. I have got a USB bluetooth adapter for the desktop PC if this helps (http://www.filesaveas.com/loox.html says that the Loox also has bluetooth, but I have not used it before). I have also got a cable to connect the Loox>desktop PC. If more info is needed, please tell.
Loox C550 will not turn on or charge, i have been charging the battery for over 24 hours, and still nothing, is there anything problem?help me please!
try replacing the battery first a deffective battery will not charge also check the contact point of the battery to the unit see if the contacts are properly connected..
Dec 03, 2010 | Fujitsu Siemens Pocket Loox 720 Pocket PC
Battery replacement pocket loox n560
If you want to buy the battery for your Fujitsu N560, kindly check these links and it might help:
http://cgi.ebay.com.sg/Extended-Battery-Loox-N560-N560c-N560e-N560p_W0QQitemZ330287493568QQihZ014QQcategoryZ75446QQcmdZViewItem
http://www.lelong.com.my/Auc/List/2009-06DeSale35361186_AUCTION_--Best-Price-Gtoracer1-Siemens-Look-400-410-420-N520-N560-Battery.htm
http://shop.eten.hu/mugen-power-3000mah-extended-battery-for-fujitsu-loox-n520-n560-with-battery-door-p-167.html
Hope it helps and have a great day!
Jun 10, 2009 | Fujitsu Siemens LOOX N560 Pocket PC
Un able to conncet to internet on my loox n520
it may have a differnt card than your device is set on
Mar 26, 2009 | Fujitsu Siemens Pocket Loox N520 Pocket PC
No connection with pc
Try loading the ActiveSync program onto your computer again. I have found this works most times. Also once loaded you have to place the T830 in the cradle for it to register as being connected. Check your type of connections to the PC in the program options as well - USB is the best, you may be on a Com port that is not recognized.
Jan 26, 2009 | Fujitsu Siemens Pocket LOOX T830...
FUJITSU-SIEMENS POCKET LOOX T 830 NOT SWITCHING ON
Try reseting the device, also try hardrest. found in manual or google, fujitsu loox t830 hardreset
Good luck.
Feb 21, 2008 | RIM BlackBerry Pearl 8100
Loox 600 doesn't start
Hey,
Have you tryed performing a hardreset on the pda?
If a hardreset doesnt fix the problem. Then it is eather a hardware issue or your operateing system is corrupt.
You can reflash your operateing system with a com or a usb cable maybe even from a memory card. But frist you need to get your hands on a working copy of the os. It might be easyer to take the pda to a local repair shop for analysis and repairs.
Feb 03, 2008 | Fujitsu Pocket Loox 600
WM6 for T830 Pocket Loox
Still BETA but WM6:
http://forum.xda-developers.com/showthread.php?t=336328
Dec 04, 2007 | Fujitsu Siemens Pocket LOOX T830...
Pocket loox t830
I had this problem. Only solution is a full Hard Reset which is a combination of Power Switch Photo Switch and Reset Switch. BUT you will loose everything on the PDA.
Jun 01, 2007 | Fujitsu Siemens Pocket LOOX T830...
Fujitsu Pocket Loox 600 Logo
53 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
