Question about Nikon Coolpix 995 Digital Camera
CF Card for Coolpix 995
What is the memory limit for a CF Memory Card for the 995
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Coolpix 995
See page 162:
So it seems that only 128 Mb is officially supported, however elarger cards may be OK but you would need to try, don't forget to format the new card in the camera. You may find a friendly high street shop that will let you try various card to see.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 03, 2008
Nikon Coolpix 995 gets a CF.Er card is not formated
bens pins inside on the camera , need to fix the card holder unit
easy to fix
Oct 09, 2017 | Nikon Coolpix 995 Digital Camera
My camera even though i have a new cf card in it keeps telling me that im out of memory. please help? its a NIKON COOLPIX5700 and the memory of the Cf card is 4gb
Having gone over a month without a response to my query, I assume my suggestion to use a memory card within the camera's specifications solved the problem.
Sep 24, 2011 | Nikon Coolpix 5700 Digital Camera
New SanDisk 4GB CF Card - Coolpix displays out of memory
This is because the Coolpix 2100 and 31000 models cannot handle a card of that large a capacity. As it's only a 2MP camera anyway it doesn't need it.
The Coolpix 2100/3100 will usually accept up to a 512MB CF card, and 1GB Lexar CF cards up to and including the 24x WA write accelerated (although write acceleration itself offers no benefits on this camera). With Sandisk only a plain old and now obsolete SDFB allows a 1GB card to be used and the regular Sandisk Ultra (not Ultra II or later) will only work up to 512MB.
The camera was discontinued long before these much larger CF cards were released and Nikon no longer actively support the product so no firmware updates will be available. The hardware wouldn't support such cards anyway.
Compatibility chart for CF cards address below:-
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/26030/c/241/r_id/127673
Jun 17, 2009 | Nikon Coolpix 2100 Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
Trying out new 4G SanDisk cf memory drives in Nikon Coolpix 5700
Not sure if this helps, but it worked for me on a Coolpix 5000.
I tried a 4Gb card, and the camera formatted it and reported out-of-memory. The problem seams to be that that max 2Gb is supported
What I did was partitioned the card into 2 sections with 2Gb on each. I then formated them to FA16.
This worked - but you can only use half of the card (i.e. 2Gb)
For the tools I used a Linux laptop with CF reader. The tools are build in here (fdisk and mkdosfat). I don't know how to do it on windows.
May 18, 2009 | Nikon Coolpix 5700 Digital Camera
"CF CARD CANNOT BE USED"
If you are not able to find your connecting cable. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and format the card once.
May be you got a corrupted card. Hope this helps you out.. :))
Mar 10, 2009 | Nikon Coolpix 990 Digital Camera
CF 4GB out of memory!
Yes..its most likely an issue with the card. Try a different card if you have one, and see if this resolves the issue.
Sep 28, 2008 | Nikon COOLPIX Cameras
Switch on - Switch off! Coolpix3100
Coolpix uses SD cards, not CF. Anyway, try using the camera without memory card, only with internal memory. If it works, then replace memory card.
Oct 01, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 995 Digital Camera Logo
394 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
