Question about Canon CLC 1000 Color Copier
Error code E350-0000 on canon clc 1000
I cant just remove this error code. is there any paticular part than i maybe have to replace to definitly get raid of this code or solve my problem on this canon clc 1000 ?
  • 67 Answers
The connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Posted on Nov 27, 2008
I keep getting error message E004-0002 ( Switch off and on again) everythime I switch on my canon clc 1000
E004 is a temperature related error. You would need to call in a service technician as it will require replacement parts.
Sep 12, 2011 | Canon CLC 1000 Color Copier
System error E.007
Hi, are you sure that you have clc 1140 Copier? Because E007 isnt clc 1140 error code. These error code is related to machines with teflon folie, in newer date b&w copiers.
These error means that copier cant see fixing folies mark, and only that you can do is to replace fixing film ( folie ).
Jul 11, 2010 | Canon CLC 1140 Copier
Canon CLC 1000 error code E075 - 0004 please help me get rid of it
[Phenomenon]
Error code E075
[Cause]
Because of the factors listed below, some problems may occur in the controls to prevent the transfer belt
shifting to one side due to malfunctions of the swing motor assembly and in such a case error code E075 gets
displayed.
1) Sliding fault of the part A in the Fig.1
2) Deformation of the sheet metal of the swing motor assembly
[Factory measures]
1) The resinous material has been added, as shown in the Fig. 2, to improve sliding.
2) The reinforcing sheet metal has been added, as shown in the Fig. 2, to prevent deformation of the sheet
metal of the swing motor assembly.
When the error code E075 gets displayed, run checks as described in the Service Bulletin CLC1000-005
(CAUSE OF PROBLEMS BROUGHT ABOUT BY ERRORS OF THE TRANSFER BELT
MECHANISM). If the error code E075 still gets displayed even after running the checks, replace the old
swing motor assembly with the new type by, following the instructions on removing the transfer belt swing
motor assembly described on page 4-50 of the Service Manual.
Affected machines
NFH01171 and later
PFH00044 and later
QFH00129 and later
RFH00079 and later
SFH00221 and later
TFH00127 and later
UFH00657 and later
Jun 11, 2010 | Canon CLC 1000 Color Copier
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
Sorry it took long to get back... I had a problem with my computer. You may have fixed it already. Have you installed a adf on this copier? If so I read in the book that you may have to replace the Left retainer plate with a new one or that it may be damaged. Here is the part number for a new style plate FF5-4662-020... Try to do a full CCD adjust with the new plate.. Good Luck
Sep 03, 2008 | Canon CLC 1000 Color Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
CANON CLC1000
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Canon CLC 1000 Color Copier Logo
327 people viewed this question
old marine
old marine
