I have speakers but i canot get them to work, not sure if it is a promblem with my computer or the speakers.. it does say 'no audio device' when i look into the sounds and speach etc of the control panel
  • 326 Answers
From your control panel then system and hardware tab, can you confirm if you have a question mark next to the sound. if it looks like what i have for my usb device(in the pic attached) then you need a driver for your sound device. youll need to find out if its on board sound or a soundcard to get the part number
Posted on Sep 03, 2008
Canot get sound out of monitor speakers.
Make sure you've connected your computer and monitor trough a audio cable 3.5mm
Also make sure the volume on your monitor is on.
Jun 18, 2011 | Advueu Technology ADV1711DB Monitor
Only woofer and rear side speakers are working. Center and front speakers are not working? Help!
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | Cyber Acoustics CA-5150 Computer Speakers
Hi, only 2 speakers work and the sub woofer also
also
hope this helps
May 21, 2011 | Logitech Z-680 Computer Speakers
Plug in speakers work fine. Internal ones do not work
also
hope this helps
May 21, 2011 | Packard Bell Speaker Computer Speakers
My speakers did not work computer say that i need to installed i try but still did not work
also
hope this helps
May 05, 2011 | System Audio Audio Players & Recorders
I can't get my rear speakers working. The surround is working because my center speaker is working
also
hope this helps
Apr 25, 2011 | Harman Kardon Audio Players & Recorders
The speakers I have worked just fine, then one day they just stopped working. Now my computer doesn't even detect them. They are plugged in correct and I haven't switched anything.
also
hope this helps
Apr 22, 2011 | Polk Audio AMR90 Computer Speakers
Help my ltop canot sound, HP Compaq Presario F700
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP Compaq Presario F500 F700 and G6000...
I just re-assemble my computer and speakers and my speakers is not working now. I am not sure if I have left a plug out. Should something be plugged into the 'Audio In" slot?
Audio in is an auxillary imput. Your speakers should be plugged into audio out. Check the power supply to your speakers. Enter Control Panel > System> and Device manager and make sure your audio drivers are working. Also enter Control Panel > Sound and Audio Devices and check the box that says "Place volume icon in the taskbar then open the volume control and make sure none of them are muted and that your volume levels are high. You can then click on the sounds tab and choose one of the sounds and hit the test button to check your speakers. Hope this helps. If all else fails check your speakers on someone else's computer.
Nov 19, 2009 | Philips MMS171 Computer Speakers
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
