Question about Gateway MT3705 Notebook
Keyboard i cannot use the traditional keyboarding without holding down the fn key
    Genius:
  • 1,239 Answers
Hi sir.
go to the control panel>keybord>hardware>troubleshoot.. it will fix the problem. please rate it.. sir .. thank u
Posted on Sep 03, 2008
Hi sir..
go to the control panel> keybord> hardware> trouble shoot. it will be helful. please rate it sir..
Disable fn key
Restart your laptop and enter the BIOS setup (F1, F2, F10 keys are common) and look for an option to 'use fn keys without fn button' or something like that.
Jan 17, 2014 | Computers & Internet
How do i disable the f keys
Hi There,
After a few hours of research, it looks like the function or F keys under windows are pre-programmed and there's not a whole lot you can do to change it. There are, however, a few options:
Keymapping software: Usually ships with (and free to download) logitech or other gaming keyboards. The software allows you to reprogram any key on your keyboard to do what you want it to.
Hold down Fn+F11, while still holding F11 let go of Fn. Some laptop users have reported that this turns off Fn keys. Also, Holding down Fn+Scroll lock or Fn+Num lock in the same fashion has had varied results.
Jun 06, 2012 | Compaq Presario Notebook Notebook
My Dell laptop keyboard settings have apparently been changed-I have to hold down the Fn key to get the letters on the keyboard instead of the Fn items indicated on the keyboard. How do I fix it?
Maybe this is the result of inadvertently turning on "Sticky keys" (see the Accessibility Control Panel Help file). Try holding the Fn key down for several seconds with no other key pressed to see if that turns off the Fn lock-on. After that you can disable the Sticky Keys function in Accessibility.
Feb 09, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Restore my acer 3680 back to factor
to restore your system to factory default....restart the system..immediately hold the AltGr key(the one right to the space bar)down...and keep tapping the F10 key...you should screen that says windows is loading file..if not try a couple of times...once you get that screen...navigate through the screen ..this will help you restore system to factory default
let me know if this helps...
regards
Dec 29, 2009 | Acer Aspire 3680 Laptop
Where can i find the volume adjustment control?
There is a Button on your keyboard that has blue lettering that is stated "Fn" without quotes. HOLD this button down, and then press the buttons on the RIGHT SIDE of the keyboard UP TOP where there are pictures of speakers with arrows going UP and DOWN. this will help in lowering and raising the volume.
So HOLD DOWN the Fn Key and then PRESS the VOLUME key you Want.
Hope this helps.
Dec 06, 2009 | IBM ThinkPad T20 2647 Notebook
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
Fn option appears in place of letters on keyboard
Sounds like you need the keyboard replaced...
Jan 08, 2009 | Acer TravelMate 2300 Notebook
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Gateway MT3705 Notebook Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
