Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Sony DCR-HC42 makes a buzzing sound
I just purchased the Sony DCR-HC42 Mini-DV Camcorder, and it makes a buzzing sound when a tape is in there and it is in Record mode, even when it's on standby. When I record the noise changes pitch, then goes back to the low buzz when back on standby. When I take the tape out, the noise stops altogether. I even tried two different tapes. Is this normal? I returned the first one and the replacement does the same thing, which is leading me to think maybe it's normal. I had an 8mm camcorder that just made noise when the tape was running. Thanks to anybody who can share some insight!
    Champion:
  • 287 Answers
Digital video drum cylinders spin twice as fast as your 8mm unit . this makes more noise
Posted on Sep 17, 2007
    Master:
  • 473 Answers
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Posted on Sep 14, 2005
Why do the sound go in and out on a sony camcorder
Could be the recording head is dirty. Run a cleaning tape through it and see if that makes a difference. Do NOT stick anything in the works to try and clean the heads by hand.
Aug 26, 2014 | Sony Handycam DCR-HC42 Mini DV Digital...
Do i need a sd card o make camera work
You can't make the DCR-HC42 work with an SD card. This camcorder uses DV tapes, or Memory Stick Duo or Memory Stick Pro Duo memory cards.
Jun 06, 2012 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Nov 30, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony camcorder
pls clean the head of camera using DV tape cleaner cassette and see if it helps pls do rate me if it helps to fix ur problem
Feb 25, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC42 Partial Screen Display
Sony has had some CCD problems with this and other model I think it is important to contact Sony at 1-866-703-7669
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera will not accept mini-dv tape anymore
Hello dear sir;
I have SONY handy cam(model 42E) that finger touch keys doesn’t work .what do I do now.
Please help me and send a procedure to repairing.
I am Iranian mechanical engineer.
Oct 24, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
291 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
