Question about Acer Computers & Internet
Unable to connect Acer Aspire 7250 to wireless broadband router (Netgear)
  • GazzaEsq Sep 03, 2008
    Yes I already have a desktop wired to it and another older Acer connected wirelessly (both operating on XP though) and both connect fine. I wondered if it is an issue with Vista or Acer's "empower" software ?
    Any light you can shed gratefully received as the vendors own 24/7 IT helpdesk are neither 24/7 or helpful !
  • andrew pester
    andrew pester May 11, 2010
    is the router already set up and running for any other pc
    President:
  • 2,961 Answers
No the empower wireless connection programme is very good but can be turned off if you wish to use Windows Wireless Zero Configuration, which may be better to try and solve the problem, if you right click on the network icon on taskbar do you get the local and internet bubble or the triangle warning sign?
If no warning, click on the connect to a network command and see if the router appears there.
If not click set up aconnection or network at the bottom of the window, then click set up a wireless router or access pont and follow the wizard, or click manually set up if you are the braver type and will have a go
If you get a warning sign i suspect the pc is trying to connect to the wrong type of encryption eg WEP when you have set WPA-PSK or visa versa or a wrongly typed passkey
Posted on Sep 03, 2008
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
Jan 18, 2013 | NetGear MBRN3000 3G /4G Mobile Broadband...
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
We just bought an aspire one acer laptop. Trying to conect to a netgear router. Help!?
If you are trying to connect the computer to the router with a cable the above diagram should help to explain the simple broadband signal path from the Ethernet or telephone wall socket, to the router and from the router to the computer's RJ45/Ethernet port. Once the computer is connected to the router by a cable is connected to a telephone wall socket or a ERJ45/Ethernet wall socket that has a 'always on' broadband internet signal coming into it, nothing else is required -> launch the Web Browser.
If you are connecting wirelessly the wall socket to the router part of the setup is the same but no cable is required between the router and the computer.
Enable the wireless function in your netbook, click on the image of two computers bottom right near the clock -> view available networks/connect to network -> click on the appropriate Netgear router signal -> connect -> launch the Web Browser.
Nov 26, 2011 | Acer Aspire One PC Notebook
I have an acer aspire 5735, when i try to connect to the internet it brings up an error and tells me i am tring to establish a second broadband connection. this has only started a couple of days ago but i...
........."Scenario: your neighbor is puzzled that his broadband performance is slow.He gets an expert like you to come and check whether his system is working properly. He is told "there's your problem - the people next door are using your connection and they seem to be downloading stuff using Kazaa and Limewire all day and all night. . the problem with that is if the two of you have the same brand of router (say Netgear), with default settings, then it won't know which is your "NETGEAR" network, and which is their "NETGEAR" network.That is why (apart from a little added security) I say to change the SSID."
"All wireless routers I am aware of have the facility to change the SSID (it usually defaults to something like "NETGEAR", or "3COM").But it is still a good idea to secure your own network - and change the SSID. If you don't change the SSID, then any neighbours with the same brand of router will have the same SSID, and your laptops won't usually know which one they are accessing. And setting the router to not broadcast the SSID is good too. But it is still a good idea to secure your own network - and change the SSID.
Sep 17, 2009 | Acer Aspire 5735 Notebook
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Cannot activate wireless between laptop and Telkom Broadband.
Bring a wireless ROuter....
Now a dayz they have wizards which make very easy to confgure them.....
Nov 30, 2008 | Acer Aspire 3624WXMi Notebook
Inter net connection
Try to reconfigure your wireless so that your broadband is controlling your wireless instead of the Acer.
Jun 17, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
