Question about Maytag Neptune FAV6800AW Top Load Washer
Fabric softener dispenser
Where does the water come from that makes the softener go into the wash? Mine doesn't empty completely and I have cleaned it serveral times. What else should I look at?
  • 3 more comments
  • janmschaller Sep 25, 2008
    Fabric Softener is not being released into washer at all. I have taken apart the actual dispenser thinking it was clogged and it still doesnt work. I have ran several cycles thru without any laundry and on hottest water cycle thinking this would break up any build up and still nothing....ideas?
  • eileendv Oct 11, 2008
    I am having the same issue with both fabric softener & bleach
  • acast481 Oct 18, 2008
    Can you please let me know how anyone fixed this issue as I am having the same problem and need some advise.
  • Anonymous Nov 24, 2008
    Brand new, and it realeases, but my clothes come out stiff. Had the stupid repairmain out and he didn't have a clue. Said use less detergent?
  • edge155c
    edge155c Nov 10, 2013
    i have changed 3 diaphrams in the valve but still dont get water into the softener compartment
    Novelist:
    Champion:
  • 261 Answers
Siphon dispensers are always holding some water. I would check the level on the machine, not over fill with softener and if not a little water to help it down. The water supply goes to the back wall under the console and a little lower in new machines.
Posted on Sep 12, 2008
The fabric softener drawer is not emptying
Fabric softener is dispensed by syphon. If the softener is not dispensing there might be a blockage in the water inlet. There is usually a twin solenoid the lets water I to the machine. One to the detergent and one to the conditioner. The water path is most likely blocked with water "debris". Try cleaning the tray and housing completely then have another go
Jan 14, 2018 | Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
Dispenser doesn't empty
You will need to clean the dispenser line.
Nov 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool duet washer fabric softener dispenser does not empty
Hi there
I wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.
I hope it works
kolbrun
Mar 24, 2012 | Whirlpool GHW9150 Duet Washer
I have a 90 series washer, about 15 years old, the fabric softener dispenser is not emptying. I have pulled it off and cleaned it, but it only works once after I do that.
HI,
I would re-clean the dispenser, use hot water can completely clean this. If you don't add water to fabric softener, it will cake up and cause this issue. This problem can also cause spotting and appear to have issues on clothing. Just soak dispenser using hot water and pressure to clean out all the ports and openings within the dispenser.
I hope this helps, worst case you can replace dispenser, but I would just clean it (cheaper).
Aug 11, 2011 | Washing Machines
The detergent dispenser want despense the fabric softner
Hello. This is a common problem due to the fact that fabric softener collects in the dispenser and gums it up. Begin with an empty washing machine. Add two cups of vinegar to the fabric softener dispenser and then run the machine on the maximum water and hottest water setting. Once the cycle is complete check it out. It will be as clean as a new machine. If this treatment didn't completely clean out the dispenser, repeat the cleaning a second time with two more cups of vinegar. regards, Joe
ps - kindly rate my answer as helpful. Thanks.
Feb 10, 2010 | Washing Machines
The fabric softener in my Maytag doesnt empty completely and a thick residue accumulates
Hello Donald,
I did not help out with much just wanted to make sure your machine type is a FAV6800A/FAV9800A. I will assume the machine type to be a FAV6800AWW. You may have gunk build up in the Fabric dispenser, I will attach some pics of opening mine, figured I would it clean up, it was a bit ugly. Place a 1” putty knife, mine is a 2.5” could not find my 1” at the location shown in the pic. Push in gently and lift up on that section of the Fabric dispenser top. Also refer to Page 33,34 of the Service Manual. Once removed check for gunk build up and clean out. I used a bleach and water solution and flushed the dispenser several times with water. If this doesn’t fix the issue we will have to verify water flow into the Fabric Dispenser. I do this by placing an external magnet on the left bumper to signal the control board the lid is closed and hold in very slightly the left lid latch on start of cycle to signal the control board the lid is locked. This is done in Service mode, I then turn on the Cold Water valve and the Fabric Dispenser solenoid in Service Mode to cause water flow into the dispenser and verify this action with the lid raised about an inch. This sound like a lot but it's a very easy process to master once ya give it a try. Maybe just a dispenser clean up will get ya going. Good luck and I hope this helps, Rich
Mar 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
292 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
