Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Follow up to your front loader question (from mozaltoff)
The timer does not seem to complete a cycle. upon further examination, the pump is not mechanically jammed and seems to spin freely. but the water will not drain (we let the water spill out when we checked the pump) there are a few audible clicks when we try to start the machine, but that is all. it "senses" that things are not working right after a few minutes and shuts itself down.
thanks for keeping with us on this.
-todd and kelly
  • 30 Answers
The fact that the timer would not complete its cycle indicates that is defective, and because your washer is not draining this may be cause by a clogged water pump.
Test the timer motor by setting your meter to the ohm and test the two motor wirers-should read between 1,000 to 3,000 if not replace.
If won't drain remove the outlet drain hose from the water pump to see if water drains freely, if not your pump is clogged.
Good luck
Posted on Sep 04, 2008
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Clothes are sopping wet even after doing the spin cycle 3 and 4 times, water is going through hose fine it seems, it a front loader
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Kenmore Energy Star 44092 Front Load...
Wher is the pump on a front loader
It depends upon the model number, but MOST front loader washers have a drain pump located directly below the wash tub behind the lower toe panel directly below the door. To remove the panel, locate and remove the screws under the bottom front edge of the panel. With the screws removed, the panel will come off, exposing the drain pump and internal components. If you need further guidance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Nov 17, 2010 | Washing Machines
Water is coming out of the bottom during the rinse cycle Do I need certified repairman or could I fix it?
Is this a FRONT LOADER? Or, is this a TOP LOADER?
If this is a FRONT LOADER, the following link explains what you have to do to determine the source of a leak:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In most cases on a FRONT LOADER, leaks are caused by the rubber door bellow developing small rips or tears due to age and wear. If the bellow is leaking, it must be replaced. The following link explains the steps necessary to do so:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have a leak on a TOP LOADER, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect a TOP LOADER for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. The choice is yours if you wish to pursue this repair on your own. In my opinion, you don't need a "certified repairman" to find the source of a leak in most cases. Many of these repairs are simple with a little guidance. Please post back with a complete MODEL NUMBER so that I may be able to povide you with better assistance. I hope this help you.
Feb 11, 2010 | Frigidaire Washing Machines
Washer is leaking under front right corner at the end of rinse cycle--occurs following all wash cycles--does not do it on ''rinse only'' cycle.
In most cases on a FRONT LOADER, leaks are caused by the rubber door bellow developing small rips or tears due to age and wear. If the bellow is leaking, it must be replaced. The following lik explains the steps necessary to do so:
repairclinic.com
Read through the instructions provided and let me know if you need further assistance. Please post back with a complete MODEL NUMBER so that I may be able to povide you with better assistance. I hope this help you.
Feb 04, 2010 | Whirlpool Washing Machines
Kenmore washing machine
Whether this is a TOP LOADER, or a FRONT LOADER, the drain pump is located directly below the wash tub in the front of the washer. Accessing either one takes, different procedures, however.
To access the pump on a TOP LOADER, you must remove the exterior washer casing. Follow the steps provided in this link:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If this is a FRONT LOADER, you must remove the lower toe panel directly below the door. Follow the steps provided in this link:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
The Kenmore Oasis is a different configuration from the two I've mentioned. There are two pumps on the Oasis. One is a drain pump, while the other is a recirc pump. Both are accessible by removing the rear panel of the washer.
If you require further assistance, please post back with a complete model number so I can determine how your washer is configured. I hope you find this information helpful.
Dec 22, 2009 | Kenmore Washing Machines
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Front loader washing machine is not draining
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Be prepared to catch lots of water. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Whirlpool Washing Machines
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
