Touch Pad The touch pad will move then stop and it continues to do that...I tried uninstalling it and troubleshooting. Please help! The same thing happens on my Toshiba Equium. It only works properly when I unplug the mains charger. I am sure this is a known problem but I have been trying to find a solution for months with no luck Toshiba did not respond to me when I posted the issue on their tech support web pages
  • glennethx Sep 05, 2008
    Yes FSecure and scanned all files without finding any abnormalities. I am starting to suspect some kind of mains noise interference
    President:
  • 2,961 Answers
Sounds like you have a virus or trojan halting the system, cannot be two faulty keyboards, do you have anti virus software?
Posted on Sep 03, 2008
Mouse pad doesn't work on windows 8
I press <alt> F5 and it will turn on/off the mouse pad!!!
Feb 17, 2013 | Acer Computers & Internet
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Feb 21, 2012 | Toshiba Satellite Computers & Internet
Curser will not move
Hi and welcome to FixYa!
If you are using the touch pad and the cursor will not move, you may want to try and use a mouse. The touch pad on your computer may have worn out. If the mouse works, it may be your pad.
Please check to make sure that touch pad button is on. If the mouse will not move the cursor, your drivers may have been corrupted and you have to download new drivers after uninstalling the old one. Which one you download will depend on what type of computer you have.
Thank you for asking FixYa!
KittyTech
Nov 14, 2010 | Computers & Internet
Touch pad stopped working
Hello, you can try one of the below steps:
1) Check if you have small on/off button for touch pad, it should be near the touch pad.
2) Remove the battery and put it back and try.
3) Try uninstall and reinstall the driver for pointing device.
Please with your progress.
(We require your rating to improve our quality)
Aug 29, 2010 | Compaq (153515-001) Touch Pad
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Hp touch pad keeps clicking like crazy....
Try the following steps...
1. First clean the touch pad with a dry cloth.
2. Disconnect the battery and the AC adapter and any other device that is connected to the NB and hold down the power button for 2 mins. This will drain the static.
3. Go to device manager and click on the + sign beside mice and other pointing devices, select synaptics / alps touch pad driver, right click on it and uninstall it. Now go to recovery manager > advance options > hardware driver installation > select the same driver and reinstall it.
This should fix it....
otherwise, go to hp.com/suppport and download the latest bios available.
you can also run a spyware scan if all the above steps do not work. go to www.filehippo.com and download antispyware program and run a scan.
Hope it helps..
Regards,
Anup
Apr 08, 2009 | HP Pavilion DV7-1023CL Notebook
Cursor Shift
This could be either a driver glitch or the touch pad is going out, both are common on these models. Start by uninstalling the drivers for the touch pad (some times referred to as the synaptic pointing device), then restart the machine. The machine will find the touch pad and reinstall the drivers automatically. If it's a simple glitch, this will fix it. If it persists, then the pad is failing and will need replaced. The only other thing you might try is to adjust the cursor speed or touch pad sensitivity from the control panel. This will sometimes help to dampen the effect, but usually won't get rid of it entirely.
Sep 04, 2008 | Dell Latitude C610 Notebook
System freezing when touchpad not being used.
This will be one of three things; 1- a driver glitch with the touch pad. Uninstall the drivers for the touch pad from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. You might also look at Compaq's support site for any updated drivers or patches for the touch pad. 2- You may have a loose connection. Remove the keyboard, check and clean the touch pad connection/connector. 3- A faulty touch pad. If the other two don't work, then disconnect the touch pad and try using the machine with an external mouse. If this works, then the touch pad has malfunctioned and needs replacing. Ty these and let me know.
Aug 01, 2008 | Compaq Presario V4000 Notebook
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
